Pages: 1 2 3 [4] 5 6   Go Down
Author Topic: MGB658 Fairmile D @ 1/72  (Read 53803 times)
Re: MGB658 Fairmile D @ 1/72
« Reply #75 on: January 25, 2015, 05:51:40 pm »
There must be something online where you can go and obtain a map. Otherwise print out a google map of the area and manipulate it perhaps?
Don't think you can get Google charts yet %%
radiojoe
« Reply #76 on: January 25, 2015, 06:50:53 pm »
Hi Longshanks
Here's a chart off Corsica, only a thumbnail but may be big enough for what you want.   {-) I used a thumbnail chart of the western approaches that is now laying on the chart table of HMS Enigma.  %%
CJ1
« Reply #77 on: January 25, 2015, 07:03:32 pm »
Any Good?
« Reply #78 on: January 25, 2015, 07:25:41 pm »
Don't forget that metric charts were not around when these vessels were.
The black and white charts are what the ships would have.
« Reply #79 on: January 25, 2015, 08:07:59 pm »
If the one you want is in colour then just set it to Monotone and size it right.
MTB Hulls
  • MTB Hulls for Shipshape Models
    • MTB Hulls picture gallery
« Reply #80 on: January 25, 2015, 08:09:33 pm »
Admiralty chart for Northern and Eastern Corsican ports;
set to print in b&w?
Christian.
http://www.mtbhulls.co.uk/
« Reply #81 on: January 25, 2015, 08:32:24 pm »
A metric chart in black and white is still metric.
Not feet and fathoms.
MTB Hulls
« Reply #82 on: January 25, 2015, 08:38:58 pm »
Quite right, although once printed to 1/72nd scale not noticeable.
Christian.
longshanks
« Reply #83 on: January 25, 2015, 10:50:04 pm »
Don't you just love the 'Mayhem'
A throw away remark this afternoon about charts .  .  .   .
and this evening I have a collection of port and general area, awesome!
I used the imperial black & white charts but I'm quite happy to convert the metric ones to black & white.
I believe the full size charts are A0 = 841 x 1189mm / 72 = 12 x 16
I suspect the Fairmile boats were using half size A2 = 420 x 594 / 72 = 6 x 8mm , I think I'll be able to get away with that  ok2
Thanks again for your support
longshanks
spooksgone
« Reply #84 on: January 26, 2015, 06:49:41 am »
22 parts to a 1/72nd Airfix Spitfire, excluding transfers? oopps, decals I mean.
longshanks
« Reply #85 on: January 27, 2015, 04:41:11 pm »
I was struggling to make the angled frames for the front of the chartroom, so I thought I'd try laminating them. Used 1.09 x .56 plus 1.09 x 0.28mm
Hope these pics show my method. first but joined the first layer
Then overlaid second layer making sure it covered the joint
I'm pleased with the results and its surprising how strong they are
Thanks for looking
longshanks
MTB Hulls
« Reply #86 on: January 27, 2015, 05:08:29 pm »
That looks spot-on  :-)  the chartroom windows can make or break a dogboat build
Christian.
radiojoe
« Reply #87 on: January 27, 2015, 06:39:39 pm »
With all that detail it actually looks larger than it is, until you look at the steel rule, lovely work  :-))
« Reply #88 on: January 27, 2015, 07:32:36 pm »
They will be much stronger than simple butt joints, which will be a good thing for when moving the boat about.
longshanks
« Reply #89 on: January 28, 2015, 09:40:04 pm »
Thanks guys,
I need your help I have a problem  O0
Looking at the front of the chartroom, the dimensions of which were taken off plans I noticed that it differed some what from the pic of 658
As you can see the centre front lower panel is not as high as I have portrayed. The question for the more knowledgeable / sharp eyed amongst you.
Is the joint between the top and bottom panels level or is the centre panel slightly higher leaving the joint at the sides to angle down slightly?
I've got it wrong once it would be good to get it right second time around, I would appreciate your views . . .
Cheers longshanks
MTB Hulls
« Reply #90 on: January 28, 2015, 09:43:59 pm »
level
Christian.
longshanks
« Reply #91 on: January 28, 2015, 10:08:04 pm »
Thanks Christian  :-))
Not much doubt there . . .
Is that one of the Air Sea Rescue boats?
MTB Hulls
« Reply #92 on: January 28, 2015, 10:20:50 pm »
That's right, known as LRRCs, (Long Range Rescue Craft).
Christian.
gra2
« Reply #93 on: January 29, 2015, 08:22:30 am »
Hi Christian,
Have you any more photos of the LRRC.
I am using your hull to make boat 040.
I will be starting a thread on Mayhem soon.
Sorry to intrude Longshanks.
Graham
gra2
« Reply #94 on: January 29, 2015, 08:29:42 am »
Sorry Longshanks forgot to  say a very nice build.
Graham
longshanks
« Reply #95 on: January 29, 2015, 07:54:59 pm »
Your welcome Graham, I seem to remember you made a fine 1/24 Fairmile D
longshanks
longshanks
« Reply #96 on: January 30, 2015, 03:59:52 pm »
Mk 2 or Oh bu**er should have checked all my references  :((
Re constructive surgery commences
Building up, looks a mess now but should clean up OK
longshanks
radiojoe
« Reply #97 on: January 30, 2015, 04:23:09 pm »
Filler and paint who's going to know, well apart from all of us that is.  %% %% {-) {-)
« Reply #98 on: January 30, 2015, 08:56:21 pm »
Is blackmail allowed on the MBM forum? {:-{
longshanks
« Reply #99 on: January 30, 2015, 10:16:16 pm »
Lol  :-))
Pages: 1 2 3 [4] 5 6   Go Up
Page created in 0.186 seconds with 21 queries.
