Thanks Peter
Just a bit of an update as I've been concentrating on the electrics which are taking a lot longer that I had ever imagined
Anyway first up I have painted and installed the anchor winch which has come out ok, and I have also modified my stand to have 6mm of baize for protection and its a nice snug fit now
Now for the start of the electronics, the inline fuse holders have been installed and the P94 mixer has been placed in the hull. Its simply held down with velcro for easy removal. The wiring on this unit is very heavy duty which gives more than a hint of the sort of amps that it can handle
I then installed the main P107 distribution board and next to it is a P103 parallel board which is connected via wires around the back
I had to extend the wires from the P94 to the distribution board so I used some 3.5mm shovel type connectors to ensure a good connection
These joints were then heat shrinked and the wires braided before being routed up the DB. I have also routed my BEC wire to the rear of the boat which is where the receiver will be
Thats it for now until more wire arrives from the component shop
I can't believe how much I'm using!
Thanks for looking - Mark
