Pages: 1 2 [3]   Go Down
Author Topic: The 1:100 Project 941UM Typhoon Build Thread  (Read 31729 times)
thegrimreaper
Re: The 1:100 Project 941UM Typhoon Build Thread
« Reply #50 on: May 11, 2015, 03:28:21 pm »
Would be good to have missiles firing but think it would fall foul of the uk firearms laws think there was something on here writen by an ex bobbie a few months (years back)
Mark.
Don't lie, thieve, cheat or steal. The Government do not like the competition.
U-33
  • K-157 Vepr. Akula-11
« Reply #51 on: May 11, 2015, 03:55:43 pm »
There's been debate over operating torpedoes and missiles fired from model boats/subs for donkeys years now...if you don't go mad with them and have the things firing forty feet up in the air, or capable of blowing up another ship, my thoughts are that you'd be ok. My torpedoes that are going in the Akula will only fire about ten/fifteen feet...enough to look good, but incapable of damaging much if they do hit anything. Look at Mick Higgott's...they look terrific, but they wouldn't even ruffle a duck's feathers.
Subculture
    • Dive-in to Model submarines
« Reply #52 on: May 11, 2015, 04:09:06 pm »
Don't necessarily have to have ballistics to get a missile going.
However there aren't much in the way of rules and regs with regard to model rockets when kept small. Just basic common sense- no launching them in densely populated areas for instance, keep a safe distance from spectators etc. private land is more restricted than common land.
The model rocket boys are the best people to speak to about all this.
U-33
« Reply #53 on: May 11, 2015, 04:14:21 pm »
Exactly...if you start firing missiles and/or torpedoes down at your local lake with Joe Public swarming all over the place, local wildlife and loads of other boats on the water, then be prepared for complaints. Just keep it low profile and you should be ok.
Subculture
« Reply #54 on: May 11, 2015, 08:22:25 pm »
I never find lithium batteries getting warm when being charged. I always charge at 1 c or lower anyway, I think it helps the cycle life.
thegrimreaper
« Reply #55 on: May 11, 2015, 11:09:49 pm »
So the miniture thermo nuclear device i have developed is a definate no no then ................."xxxxx"
Mark.
U-33
« Reply #56 on: May 12, 2015, 06:39:58 am »
Mark.
Remind me to have a word in your ear on Sunday...
thegrimreaper
« Reply #57 on: May 12, 2015, 07:53:14 am »
Sunday why whats happening on sunday ??
Subculture
« Reply #58 on: May 12, 2015, 12:01:53 pm »
Bournville Dive-in.
Davy1
  • Association of Model Submariners
« Reply #59 on: May 12, 2015, 04:18:04 pm »
It is the Saturday actually.
See everyone there!
David F
thegrimreaper
« Reply #60 on: May 12, 2015, 05:02:04 pm »
Thought it was Saturday just putting it down to a senior moment on the part of the old codger  lol
Mankster
  • Wheelerdealer
    • RC Model Submarines
« Reply #61 on: May 23, 2015, 11:33:18 pm »
Mankster
  • Wheelerdealer
« Reply #62 on: May 25, 2015, 08:25:52 pm »
Some more work....
Do we all read the same books?
Jack D
« Reply #63 on: May 25, 2015, 09:33:00 pm »
Is that a bow thruster I see there? I take it the motor to drive the unit is back in the WTC and that brass rod just drives the mechanics inside the thruster. Also, does the position of the thruster being off centre make any noticeable difference to thrust on either side?
« Reply #64 on: May 26, 2015, 10:25:39 am »
Hi Ramesh,
May i ask the size of the Bow thruster your using?
And is it prop driven or paddle?
Mankster
  • Wheelerdealer
« Reply #65 on: May 26, 2015, 01:04:04 pm »
Hi Adam, it's the standard 14/16 paddle bow thruster made by Raboesch
I can imagine the bow thruster body being off centre will make any differance. Of course I haven't tried it yet.
Subculture
« Reply #66 on: May 26, 2015, 07:24:54 pm »
Could always use small centrifugal pumps like the Spanish modellers did a few years back. They used brushed versions but you can get brushless versions now, and they cost peanuts if you buy them direct from China on ebay.
Probably be a bit slower than a dedicated bow thruster unit, put you can use small holes which are more discrete.
Albion
« Reply #67 on: May 27, 2015, 03:10:27 am »
centrifugal pumps only flow in one direction irrespective of which way they rotate
vnkiwi
« Reply #68 on: May 27, 2015, 03:56:36 am »
one scroll case, two radial outlets, flaps control flow from either.
Flows in pump is always one way, but exits either side dependant on flap position.
simple flap switch control, Left or right, no reversal to motor.
Albion
« Reply #69 on: May 27, 2015, 04:09:11 am »
its a good solution to a non existent problem!  ok2
vnkiwi
« Reply #70 on: May 27, 2015, 06:37:09 am »
one suggestion of at least a dozen solutions to the use of centrifugal pumps as thrusters in model boats, no problem at all.
Mankster
  • Wheelerdealer
« Reply #71 on: June 27, 2015, 10:42:23 pm »
Still a bit more work to do on the hatches....
Mankster
  • Wheelerdealer
« Reply #72 on: June 28, 2015, 05:43:22 pm »
Mankster
  • Wheelerdealer
« Reply #73 on: October 26, 2015, 10:19:44 pm »
Haven't done much for a few months. I'll get back on it over the winter.
Pages: 1 2 [3]   Go Up
Page created in 0.28 seconds with 17 queries.
