Hi there some more of the build.
1....Ready to spray the 2nd or was it the 3rd gloss coat ? had so much trouble with particular brand of paint, I have always brushed the gloss enamel ,but being larger area and the higher humidity I decided to spray ( I thought why not ,I now know why not
) I would normally go for Dulux but couldn't get the gloss finish in the Dulux so settled on British Paint gloss enamel 1st and last time. Even after a few days letting the coat harden ( well so I thought) if used bit of turps to say wipe a smidgen of paint off it would smear the gloss off it
, even when taping over it to paint beside it ,it also took the gloss off with the tape ( never had that problem before).
2...Showing the model before painting the Royal blue dog leg around the waterline.
3...all the mast stays to their correct lengths.
4...Mast, boom pre fitted to the hull.
5...With the model.
6...I installed a 12 V computer fan ,running it on a 9 V battery (running time bit over an hour) just to push a bit of air through the hull, I have one of the hatches on the deck with a slide out section , you can feel the air exiting quite well through it.
