Author Topic: Recommend an airbrush set up?  (Read 1952 times)
adamD98
  • Born free, forced to work!
« on: December 17, 2014, 10:25:16 PM »
Hi all,
 I am about to venture into the world of airbrushing properly, so I wondered what you would recommend to me as a decent but budget cautious set up? It must be able to handle 2-pack paint also... If that is relevant.
 Thanks in advance for any advice folks.
Cheers,
-Adam-
Jherek
Re: Recommend an airbrush set up?
« Reply #1 on: December 18, 2014, 12:05:48 AM »
You can easily spend 2-300 quid on a compressor and 150 quid on an airbrush but I would recommend one of the Chinese air compressors from ebay, search 'as186'. These are cheap compressors with a tank (which is important). Some of these compressors come with airbrushes which are good for one thing only - the bin (or maybe cake decoration).
I started with an Iwata Neo CN, japanese designed, but Chinese made. These are about 40 quid and well worth the money. I have a Harder & Steenbeck Evolution now, but I still use the Iwata.
adamD98
« Reply #2 on: December 18, 2014, 10:10:07 AM »
Thanks for the reply.
 I have a pretty large model (16' approx) to refurb, hence the need for a proper set up this time around!
Cheers,
-Adam-
Jherek
« Reply #3 on: December 18, 2014, 05:41:59 PM »
16 foot?  :o
I'd go for a spray gun for the larger surface areas, you can use something like the 'citadel spray gun' which is cheap for starters. The airbrush I suggested is a double action airbrush for finer work.
« Reply #4 on: December 18, 2014, 06:14:03 PM »
Jenny's Sideparty would do a good job with
brushes and rollers.  :D :D :D
They know the right shipside grey to use %% %%
« Reply #5 on: December 18, 2014, 06:19:06 PM »
Hang on a mo Right top tip here......go along to Machine Mart and buy yourself a 50 ltr 12cfm compressor and whilst you are there buy a cheap gravity fed spray gun ....if it's the boat I think it is that has had a new home up at yours then you are going to NEED IT.An airbrush wont hold enough Paint for your needs
sailorboy61
« Reply #6 on: December 18, 2014, 06:28:19 PM »
Or take her to a back street body shop and negotiate yourself a deal! :-))
adamD98
« Reply #7 on: December 18, 2014, 06:43:19 PM »
Thanks Stav (and everyone else) it certainly is the boat your thinking of, a certain Type 45?
Only needs a few touch ups here and there, not a full re spray.
I've only ever used tiny guns for small parts before now.
Cheers,
-Adam-
