Author Topic: Help Please with R/C - What Goes Where?  (Read 3674 times)
Pearlsfirstmate
  • Pearl - the real thing!
« on: December 18, 2014, 03:49:27 pm »
Hi Guys,
Coming to the end of building the Aero-Naut Bella (there's a build blog on the Yachts & Sail board), but as I'm "Home Alone" can you advise me (in very simple terms please) what plugs into where and which way round for the r/c.
I have a Planet T5 R/C but can't find the instruction booklet and I've found a bundle of what I think has been put to one side for me........ ;)
I've mounted on the bulkhead the Planet R6M 6g Micro 2.4 Ghz Receiver and have the following to plug into it.  Pins are marked B 1 to 6 and are in rows of 3
Red & Black into a connector from the 4 AA Battery Box (presumably B)
Yellow Red & Black into a connector from the sail control servo
Yellow Red & Black into a connector from the rudder control servo
This is my first R/C Yacht and I've not got a lot of experience when it comes to these "clever bits".
Any help very much appreciated  :-)
Eve
Re: Help Please with R/C - What Goes Where?
« Reply #1 on: December 18, 2014, 04:35:18 pm »
Of the three pin Black is negative, red positive, yellow signal, so the middle pin is positive. Usually the bottom pin, ie the opposite face to that with the numbers printed is negative.
The channels usually go left vert = 3, horz = 4 right vert = 2 horz = 1
HTH
Brian60
« Reply #2 on: December 18, 2014, 05:02:25 pm »
If you look at the end of the rx they have printed a + or it could be the - to indicate which wire of your plug should go to it.
Pearlsfirstmate
« Reply #4 on: December 18, 2014, 06:55:25 pm »
Thanks very much for all the advise and info guys, I'll go and have a play....  :-)
Pearlsfirstmate
« Reply #5 on: December 19, 2014, 02:02:56 pm »
Guys, All seems to be working but the sail servo continues to make a buzzing noise - why would that be? Any ideas please
Many thanks
« Reply #6 on: December 19, 2014, 02:40:30 pm »
Does the Rudder servo work?
If so, swap the rudder and sail servo plugs over and see which one still works.
Pearlsfirstmate
« Reply #7 on: December 19, 2014, 03:52:08 pm »
Hi Martin, they are both working fine but the sail servo buzzes all the time there is power to it.
Grateful for your help  :-)
« Reply #8 on: December 19, 2014, 04:13:46 pm »
Does it Buzz with or without the sheets attached to it.
It may be trying to go further than the sheets allow.
The channel you are using has a failsafe.
Try switching on the Transmitter and centering the stick.
Then switch on the receiver.
This should set it's limits.
Pearlsfirstmate
« Reply #9 on: December 19, 2014, 04:40:47 pm »
Well, I've just slightly loosed the screw on the sail servo arm and it's stopped buzzing !!
How good is that  :-))  All working perfectly - thanks to you guys.
Can now show off when his nibs gets back  ok2
« Reply #10 on: December 19, 2014, 04:54:32 pm »
The screw needs to be tightened, not left slightly loose.
With wind in the sails there is a lot of tension on the
Sail arm.
Worst scene scenario is the screw pulling out and
Stripping the thread in the servo.
Hey Presto. New servo needed.
Pearlsfirstmate
« Reply #11 on: December 19, 2014, 05:23:12 pm »
Ned, thanks for that and I understand what you are saying. I can assure you the screw is not slightly loose just me over tightening it in the first place.
Thanks though for your words of wisdom, much appreciated and I'm sure "his nibs" will double check on his return. Nice though that I'm one step ahead of him, all thanks to you guys. Ha  :} :D
Page created in 0.105 seconds with 22 queries.
