Thanks for the info George, it seems like the Sun is not the thing to be swapping in to the paddler but I am not concerned, it is a nice engine to have on my window sill and one day I will get around to building something suitable to put it in, perhaps with the variable prop. At some time I will also find a twin cylinder reversing engine for the paddler. The pump will come in useful and the reverse gear set up is interesting. I will pull it apart and put some pictures on Paddleducks as thats where it should be of most interest. It is not separate output shafts, one shaft goes right through. The bevel gear hub slides along the shaft and depending which bevel is engaged with the one on the flywheel determines the direction of rotation of the output. It needs a selector fork making to engage in the groove in the bevel gear hub and it also needs a roll pin across the shaft to connect the slot in the hub to the shaft so it has obviously never been run in a boat but running the engine slowly on air and shifting the hub by hand it does go in to gear easily and there is room for a neutral position when neither side pinion is touching the engine one. I think it will be more suitable for a relatively low power steam paddler. Again, thanks for sorting me out, I always come away from Mayhem inspired to go do some more work and retirement is coming SOON! Cheers, Ian.
