Author Topic: LED / Fibre Optic ...  (Read 15398 times)
g6swj
  • Short Wave Jammer! -.-
Re: LED / Fibre Optic ...
« Reply #25 on: December 27, 2014, 10:58:07 pm »
EL cable Does not get hot very flexible - you can get splitters etc so you can plumb it- joint it etc I think
Pretty cool stuff
Jonathan
g6swj
« Reply #26 on: December 27, 2014, 11:03:26 pm »
http://proto-pic.co.uk/lime-green-el-wire-2-5-metres/
EL Wire, also known as Electroluminescent wire is a stiff wire core coated with phosphor and then covered with a protective PVC sheath. When an AC signal is applied to it, it glows an aqua (blue green) color. You can make it look different colors by changing the coating, for example this is a vivid lime green. It looks a little like thin neon. Very bendable, it keeps its shape and you can curl it around your finger. Its an easy way to add some glow to a project, not as bright as LEDs but uses a lot less power!
We've got 2.6mm thickness EL wire, with a lime green coat, pre-cut and soldered to a standard quick-connect EL wire. It is made with the latest technology and twice as bright as 'standard' 2.3mm EL - running it at 1.5KHz/90V it emits 123 cd/m^2 or light and a half-life (50% brightness reduction) after 3000 hours of continuous use. Draws about 10mA per meter. The capacitance is about twice that of 'standard' EL, 11 nF/m so if you're using an inverter, it will drive only half as much high brightness wire as standard.
Often used for costuming, decoration, accent lighting, safety vests, bicycle/motorcycle/car/boat/home decoration, signs, etc! This wire is not designed explicitly for outdoor use so it will fade if continuously exposed to UV.
To use, the wire must be connected to an inverter that provides an AC supply of approximately 100V at 2000 Hz. This wire is 250 cm long which is the maximum that can be driven by our handy 2xAA portable pocket inverter The full length draws 200mA from the 2xAA batteries (so 2000mAh batteries will last ~10 hours if on 'constant' mode)
flashtwo
« Reply #27 on: December 27, 2014, 11:14:12 pm »
I bought one these evaluation kits:-
http://shop.surelight.com/3_piece_el_wire_evaluation_kit.htm
They work very well, but now I'm just trying to think of an application on my boats. Batteries were included with mine!
« Reply #28 on: December 27, 2014, 11:25:52 pm »
A very INTERESTING product indeed
« Reply #29 on: December 27, 2014, 11:52:58 pm »
I bought one of those electric wire things a few years ago... I wonder where it is.
« Reply #30 on: December 28, 2014, 12:19:31 am »
MMMM you didnt get rid of it when you had the MEGGA shed clearence did you Martin
RAAArtyGunner
« Reply #31 on: December 28, 2014, 12:46:40 am »
Switch it on and it will show up %) %) %)
Ben Kenobi
g6swj
« Reply #33 on: December 28, 2014, 07:47:07 am »
Led light pipe plus if possible tri colour led would be really neat -just pick your colour  :embarrassed:
boman
« Reply #34 on: December 28, 2014, 07:52:57 am »
FWIW, I bought a cheap lamp years ago. It had a plastic chrome base and about 200 fine fibre optic wires attaches. More than I will ever need. You can bend them well, as long as you do not kink and the light still comes out the end. You also get a battery operated light source too..
« Reply #35 on: December 28, 2014, 10:06:30 am »
This link - http://www.instructables.com/id/How-to-Solder-EL-Electroluminescent-Wire/#step0 - talks cheerfully about using a battery pack with no mention of AC.  Or volts or current for that matter.  In situ on a boat, it might just be as fault prone as anything else, but more difficult to service.
Years ago I was involved in making a control panel for a model rail layout - we used a lot of fibre for the route indication.  That was offcuts from a "horses tail lamp" manufacturer, thus cheap and plentiful.  Exchange & Mart was a wonderful thing back then.  We used mini lamps as a source due to them being easy to get and a bright light source.  We could get 10 or a dozen fibres into a tubular ferrule (paper sleeve) that was a sliding fit over the bulb.  To maximize the light going into the fibre, since it was plastic rather than glass, we heated the end in a flame and tamped it so it had a conical shape and a flat end.  The other end got the heat treatment but was untamped, forming a bulb.  This arrangement was quite visible in normal light.  As noted before, it did not like tight curves.  I put this down to the stress patterns that formed at the curve giving different reflection/refraction patterns, lighting up the bend rather than allowing the light to the other end.
Edge lit light guides do work well, but you need to make sure that there are absolutely no blemishes anywhere, other than where you want the light to exit.
g6swj
« Reply #36 on: December 28, 2014, 10:35:01 am »
This is a neat pack 12volt in
http://proto-pic.co.uk/12v-el-electroluminescent-wire-tape-inverter/
Can power 6m high brightness / 12m normal EL cable
No reason to be fault prone if installed well both physically and electrically
Regards jonathan
david48
« Reply #37 on: December 28, 2014, 11:28:49 am »
Fiber optics were used in the sauna roof to give a twinkle to do this all the fibers were brought back to an acrylic rod and the fibers were attached to this by heat shrink . The rod was clamped and a halogen bulb used as a light source , Ultralight Led could be used . Between the light and the acrylic rod was a disk with a pandom pattern of holes and slots all different shapes with coloured film on them ,a motor turned the disk making the lights in the sauna cabin twinkle like stares and all different colours .  This had one bright white light but gave lots of colours . This piece of kit was made by Swervoski the jewelry /binocular people .
David
dpbarry
  • If it ain't broke, break it and curse fixing it!
    • Newcastle Lifeboat Station
« Reply #38 on: December 28, 2014, 03:21:48 pm »
You can also find elwire, elpanels etc at http://elwirecraft.co.uk/
Good site. Used them before
Declan
hmsantrim
« Reply #39 on: January 03, 2015, 10:30:01 pm »
 hi ben K.
 think I have found what you are looking for, in ther B&Q cat an LED flexiblelighting film which you can cut to length.  its just like a roll of double side tape.
frank
https://www.google.co.uk/search?sourceid=navclient&ie=UTF-8&rlz=1T4GUEA_enGB581GB581&q=juniz+flexible+lighting+film
 googled some others for comparison
https://www.google.co.uk/search?sourceid=navclient&aq=&oq=juniz+flexible+lighting+film&ie=UTF-8&rlz=1T4GUEA_enGB581GB581&q=flexible+lighting+film&gs_l=hp..1.41l3.0.0.1.2016410...........0.rEWWnYbxX-c
« Reply #40 on: January 04, 2015, 11:15:32 am »
The tapes are sets of three LEDs repeated along the length of the tape with power (12 volts) fed in from one end.  Great for fish tanks and applying full size strip lighting, but I feel that they would be of very limited use on a model.
Page created in 0.107 seconds with 21 queries.
