Model Boat Mayhem - Forum
Author Topic: Revell 1/72 Gato Class  (Read 11916 times)
ojays
« on: January 09, 2015, 08:33:42 PM »
Having completed my Italeri S-100 Schnellboot, I saw a thread on another modelling site of an amazing build of a Revell Gato Class Submarine.
Although it was only for static show, it has inspired me to change genre yet again.
I know I can never reach the standard that the builder of that particular project managed, however I like a challenge and have started my build of this subject.  I intend to incorporate some of his techniques, but intend it to have R/C only as a surface runner at present
Age is but a number!
ojays
Re: Revell 1/72 Gato Class
« Reply #1 on: January 10, 2015, 04:19:40 PM »
Modifying the kit prop shafts to be operational, required separating the tunnels from the kit tunnel/shaft combination.
Unfortunately the first tunnel I attempted to drill out, I had the drill speed too high and partially melted the plastic.
This done, I initially I used carbon fibre rod to line up the drilled out kit 'A' frame and tunnel, before replacing with brass tubes and permanently attaching the tunnels to the rear hull sides.
This allowed me to mark off where the shafts would enter the bulkhead in the main hull.
Captbearuk
« Reply #2 on: January 10, 2015, 05:49:31 PM »
I like this.  :-))
ojays
« Reply #3 on: February 15, 2015, 10:08:57 PM »
Iv'e not had the ability to do much for a while, so now I am trying to get as much done as possible.
I am going to be laid up for a few weeks,  (new left shoulder op) so I am trying to get the difficult/fiddly jobs out of the way
Managed to get a little work done over the last few days, mainly to the PE deck areas & diving planes.
My intention had been to build as a surface runner, but as others have already said, I would change my mind once I got going.
Following advice given by more knowledgeable persons than myself, I have increased the area of the diving planes by 30% using plasticard extensions.
The PE decking was a pain to fit, but hopefully it will pay off when all is painted.
ojays
« Reply #4 on: February 18, 2015, 08:32:47 PM »
While waiting for a WTC to be made up by Marks Model Bits, got a little painting done as it was such a nice day outside today.
A thin coat of primer to show up any imperfections that need some attention. (quite a few areas)
salmon
« Reply #5 on: February 19, 2015, 01:30:24 PM »
You are doing a great job on the sub. Are you crafting this sub as a WWII sub? If so, you will need to open the hatches on the sides of the sail. An area I would remove is those rectangle weld lines only one or two subs had them and it was a post war addition. I did not think about that when I did mine.
If you can cut, drill, saw, hit things and swear a lot, you're well on the way to building a working model sub.
ojays
« Reply #6 on: February 24, 2015, 11:33:45 PM »
Great looking Sail there.
Will probably leave this semi sealed, as playing with the idea of making a mini WTC with the receiver in it. (2.4Ghz)
Tonight started on the Eduard PE side hinge plates, the job I have been putting off for quite a while.
Folded and temporarily attached with masking tape, until I have worked out the areas that need fettling around obstructions.
ojays
« Reply #7 on: March 18, 2015, 09:23:50 PM »
A few bits and pieces arrived courtesy of MMB & S.H.G.
Just need some spare time to get moving on with this.
salmon
« Reply #8 on: March 29, 2015, 05:33:01 PM »
How is the sub coming along?
ojays
« Reply #9 on: April 03, 2015, 08:06:01 PM »
Not a lot to add recently, as having problems with a shoulder I'm waiting to have replaced.
Unfortunately this makes it difficult to use my left arm/hand.
I will hopefully post some of the minor updates over the weekend!
Gregg
profesorul
« Reply #10 on: April 06, 2015, 07:24:43 AM »
@ ojays ,
I'm sorry to hear You are not in Good Shape .   ok2
My Best thoughts and Good HEALTH , to Recover Soon .    :-)
MARIUS
ojays
« Reply #11 on: April 11, 2015, 07:59:25 PM »
Thanks for the comments Marius, just one of the joys of life catching up with me!
Not a lot to show but been playing about with positioning prop shafts, modifying dive planes, and fitting the 'Eduard' PE side plates (a lot easier with Cyano Gell) as it gives more time to position.
ojays
« Reply #12 on: May 17, 2015, 10:34:18 PM »
Managed a little over the last few weeks.
Control rods/runs for the dive planes & rudder trial fitted, to check for freedom of movement.
U-33
  • K-157 Vepr. Akula-11
« Reply #13 on: May 18, 2015, 08:03:34 AM »
There's rumours that the Gato may be coming back in production....
« Reply #14 on: May 18, 2015, 12:58:46 PM »
Where did you get that little 2 outlet gearbox?
I looks like the one fitted to some older Tamiya battleships only with metal gears
RAAArtyGunner
« Reply #15 on: May 18, 2015, 10:15:17 PM »
The 'motorised' Lindberg PT 109 kit, has one similar.
One motor, with two outputs.
ojays
« Reply #16 on: May 18, 2015, 10:16:02 PM »
Heard the same, hopefully it will bring the price down to a more affordable level.
These are going for silly prices on e-bay.
ojays
« Reply #17 on: May 18, 2015, 10:16:59 PM »
Found it an e-bay a while ago!
 Gregg
eddiesolo
« Reply #18 on: May 18, 2015, 10:23:12 PM »
Nice work Gregg, coming together nicely.
Si:)
ojays
« Reply #19 on: May 20, 2015, 08:50:36 PM »
Thanks Si, forgot you peruse this site too.
Starting to struggle with this now, with the shoulder problem. {:-{
Had pre -op assessment today, and will be informed within the next 28 days of op date.
Told arm will be strapped up for first 3 weeks after op, then at least 3 months before it will be functional. :(( :((
Not a happy bunny as modelling is my way of coping with things. :(( :((
Still, onward & upward.
Gregg
salmon
« Reply #20 on: May 21, 2015, 01:55:13 AM »
I can relate. Just had surgery for cancer on my lower spine and can not sit for weeks. Going stir crazy.
Your build is coming along, we can wait until you get back to it.
Peace,
Tom
ojays
« Reply #21 on: May 21, 2015, 11:25:55 PM »
Peace,
Tom
I know just how you feel Si, I had a spinal fusion several years ago, and the three months of only being allowed to lay down or stand up, with no sitting did my head in.
However it did get rid of 30yrs worth of pain & painkillers I had been suffering.
At this time my wife allowed me to use the kitchen worktops (just the right height) to work on my R/C aircraft without having to bend etc..
Anyway I do hope that your back improves soon.
Gregg
ojays
« Reply #22 on: May 28, 2015, 12:31:38 AM »
Gearbox to prop shaft, connected through secondary shafts and UJ's.
ojays
« Reply #23 on: January 12, 2016, 11:11:57 PM »
Hopefully back on board this year.
A few medical problems and complete lack of modelling mojo for a while now.
Hopefully over it and make some progress on this, as like most of us I have built up a stash in my cupboard I would like to get into.
Strange! No interest in building, didn't stop me from accumulating several more kits though.
Gregg
salmon
« Reply #24 on: January 13, 2016, 03:47:56 AM »
Gregg
Oh,you got it bad. Yep, incurable modeling disease. Some say it is caught when you touch plastic and work with it, others believe it is an overload of pride when you complete a model, still others think it is because of the thrill of learning and the challenges each model brings. I do not know what it i, but I have dozens of models in boxes that I have collected over the past several decades. I have been trying to limit my acquirements to sub related. That has been my most recent discipline. My next one is to sell the ones that are not sub related.
