Author Topic: gooseneck  (Read 3108 times)
dasboot6419
gooseneck
« on: January 12, 2015, 09:55:34 pm »
does any body know were I can get 2 goosenecks for the inga4, any help would be great thanks..
I will insert a pic of the type of goosenecks I need.
pugwash
Re: gooseneck
« Reply #1 on: January 12, 2015, 11:13:22 pm »
It might be possible to make them if I hadn't gone blind trying to see them on that tiny pic.
Can you put a bigger photo on please
Geoff
dasboot6419
Re: gooseneck
« Reply #2 on: January 12, 2015, 11:50:18 pm »
tried to make it bigger
hmsantrim
Re: gooseneck
« Reply #3 on: January 13, 2015, 01:30:55 am »
Hi.
 have you not got plans to work from.
 Frank
roycv
Re: gooseneck
« Reply #4 on: January 13, 2015, 11:57:03 am »
Hi das......  can I offer you another solution?  I have on two of my yachts fitted this system.  Sorry no picture.  I use 1/8th inch dia. plastic aileron hinges about 1 1/4 inches long each side of hinge.  Standard items in Model aircraft shops.
Drill a hole into the boom and slide plastic hinge in with 3/8ths inch sticking out and hanging straight down.  Glue in place.  Then fit a 3/4 inch length of tube to mast for the other part of the hinge to rotate in, a fairly close fit.
The boom needs to be held down by the kicking strap.  The hinge allows boom to rise and the tube for it to go from side to side.
Paint the tube on the mast the same colour as the mast and you will not notice it.
Has worked well for years and easy to remove boom from mast.
Hope it helps,
I have an Inga lV very nice but rather heavy.
Roy
rickles23
    • Royal Navy Commandos
Re: gooseneck
« Reply #6 on: January 13, 2015, 02:22:58 pm »
http://www.modelyachtfittings.com/
He makes good brass fittings and if spoken to nicely he might give you a price for custom made fittings.
Worth an email.
Klunk
Re: gooseneck
« Reply #7 on: January 14, 2015, 11:05:04 am »
full time penguin
dasboot6419
Re: gooseneck
« Reply #8 on: January 14, 2015, 09:30:15 pm »
ok will do thanks.
