Thanks for the replies. Now, is this too much motor for the esc? I was thinking that the esc would be able to handle 40 amps without water cooling. OK, I think that I see where you guys are coming from. The ideal thing would be for me to build a test jig with, say a 45mm prop, add some forced water cooling and try again. Would the prop then be loaded if this setup is static?
