There's nothing new about epoxy resins, they've been around about the same amount of time as polyester resins. Polyester got the edge on price, so epoxies tended to be regarded as more exotic as they were used more in the aerospace industry.
The Lotus Elite (circa 1959) used epoxy resin for the doors, although the rest of the shell was moulded in polyester resin, which reduced cost where the higher performance wasn't required.
One thing you do need to bear in mind with epoxy is that you need room temperature or higher for the resin to cure properly. Polyesters can be made to cure in quite cold conditions with the right catalyst, but with epoxies, no dice.
Fortunately they don't pong in the way polyester does, so you can often bring the project indoors for curing
