Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16   Go Down
Author Topic: SD 14 Card Model  (Read 131744 times)
Howard
Re: SD 14 Card Model
« Reply #350 on: October 11, 2021, 09:26:37 am »
Hiya Rich,
I would not call it a contact glue, I put it on and fix it straight away bit like using the old Airfix tube glue but better and it works so far.
                   Regards Howard.
Howard
« Reply #351 on: October 13, 2021, 10:12:30 am »
Morning Gents,
A small step maybe to you but a huge step forward to me, After spending all day having more tests done at Grimsby hospital I managed to finish the Swagging on the superstructure and as you will see did the engine room skylight, Derrick posts for number five hold,  and a vent on the back of the funnel. Hands are feeling a little better[/size] Next am aiming to try and make the Signal Mast, Ventilators, Cargo and topping Winches as there's a few of both of these I'll made one of each  and then make a silicone mould to cast the others.
[/size]                        Regards Howard.
Howard
« Reply #352 on: October 13, 2021, 10:28:51 am »
here's some photo's
      Regards Howard.
Howard
« Reply #353 on: October 13, 2021, 10:33:02 am »
and this one
chipchase
« Reply #354 on: October 13, 2021, 01:47:32 pm »
Very nice Howard lots of fiddley bits on that  :-))
Howard
« Reply #355 on: October 14, 2021, 04:19:42 pm »
Hello Gents,
Am looking for a bit of help wanting to see if am up to making the Cargo and Topping Winches thing is looking at the card one's  even if I managed to cut them out I think they will look crap but all you book and pictures I have I cant any that look what I need
I will make a handed one of each then make a silicone mould and cast then in resin so if any of you great guys have any plans or clear pictures you could send me it would make me a very happy man and would make my hands so happy too, Mayhem has never failed me yet, thank you for your time if you can help.
            Regards Howard.
SailorGreg
« Reply #356 on: October 19, 2021, 09:04:41 am »
I can't help you with the winches I'm afraid, but I want to say how lovely it is to see you building again.   :-)) :-)) :-))
Greg
Howard
« Reply #357 on: October 19, 2021, 12:04:28 pm »
Hello thank you Greg,
 am so pleased myself that am at least able to do a little huge leap forward for me I have been back to Grimsby this week for more Specialist tests so now it's back to Scunthorpe Hospital and see what the Specialist says there Right hand is nearly back to normal left about 50% anyway am back modelling  so am a happy chappy.
                 Regards Howard.
« Reply #358 on: October 20, 2021, 07:09:56 am »
Just a heads up Howard,
Boyes sell Mitre Bond.
Might be worth trying a small
Bottle.
« Reply #359 on: January 10, 2022, 10:50:30 pm »
Hey Howard!
 How you doing?    :-)
Howard
« Reply #360 on: January 10, 2022, 11:03:54 pm »
Hello Martin,
 Thank you for asking I'll write you a heads up tomorrow as a bit late now some good but most not great and with Covid every things just getting pushing back am trying to keep up-beat but finding it very hard  where's so little I get do now.
          Regards Howard.
« Reply #361 on: January 10, 2022, 11:25:54 pm »
Howard
« Reply #362 on: January 11, 2022, 09:21:05 pm »
Hello Martin,
I know this is a little off thread as  at the mo I cant go any further with the SD14 owning to my health  my right hand is a little better but my left one and am left handed is much worse very painful pins and needles 24/7often can only snatch a few hours at a time if any at night right one the same but not as bad been over a year now but with covid things just seam to be kept pushed back really doing my head in not able to do my modelling am trying with much luck to fit out my little 1:72 scale puffer with all the black art stuff but only have a 110mm x 50mm hole to work with battery's under Neath and RX, esc, switch, a ActionP69 plus a Action p64a micro stream engine sound puffer version plus all the wirers and cables I think i might struggle with these hands but some how I'll not be beat.
 right back to what has been found out about why am so unwell thought it was my stent  had  angiogram no its ok had, two echo scans of my heart  and found the bottom right hand chamber in my heart is not squeezing much so not emptying so cant fill back up again fully, down side  is why my body's not getting enough  oxygenated blood around my body am 90% ok when sitting doing nowt  but as soon as I get up and try and do anything I start getting very breathless and start shutting down can walk about 50 yards if that its so peeing me off when I have been so active  think it might be from a Heart Attack I had 39 year ago that did the damage so been waiting since early November to hear what they can do if anything am so sorry the lads might have to wait a bit longer to see the SD14 have more done am as frustrated as them.
once I hear anymore Ill let you lads know am just so pleased people or still interested.
           Regards Howard.
« Reply #363 on: January 30, 2022, 06:13:32 pm »
From Facebook ....
https://www.facebook.com/groups/3254456231264232/search/?q=SD14%20
Good evening everyone
i made a new years resolution for no new kits during 2022, and then joined a 90 day group build, all i had untouched was the stern section of the Marcle 1/70 SD14 card kit so here i am on day 8 and hoping i can get it across the line in time
she will be set in a ship breaker diorama, so not everything needs to be built up.
Kevin Aris
Howard
« Reply #364 on: January 30, 2022, 09:02:20 pm »
You will now understand what i meant about all the card cutting an hundreds of slots to cut and that's with good hand to work with  Martin good luck mate.
    Regards Howard.
Howard
« Reply #365 on: January 31, 2022, 08:38:31 pm »
Hello Martin,
 Am just thinking it you get into   cutting card  and love making 1mm slots  you might want to finish my SD14 as I think it may be a while before my problems are sorted out just wondered cutting out thousands of slots night after night so so relaxing and rewarding {-)  as you will find out
               Regards Howard
kevin547n
« Reply #366 on: June 07, 2022, 05:35:32 pm »
From Facebook ....
Kevin Aris
lol i recognise that build
Amerigo Vespucci -  Panart - 1/84
https://www.modelboatmayhem.co.uk/forum/index.php/topic,66456.0.html
I tend to do a lot of building at the weekends, then ponder what i have achieved during the week, then adapt, redo or accept the following weekend
Howard
« Reply #367 on: January 26, 2023, 08:01:27 pm »
Hello good evening Gents,
 Just letting you know am still alive been ill with a bowel cancer scare but all sorted when for some reason I could not get logged into Mayham for months even with Martins Help but at last this week Martin got me up and running again Sd14 is on hold till weather gets better as i need to do that in the garage at over 7ft to big for my indoor model room been trying to get my mojo back casting bits in resin finishing my 1:72 puffer, and painting my Victoria yacht to look like the Hull & Humber round the world Yacht race  Hull and decks all done just waiting for new white sails to come, £75. so not cheap never used the Vitoria sails or decals still in they bag so might see if i can put them on flea bay I still not got the heart problem sorted so have to watch just how much I do as it only running at 37%  just so nice to be able to see and post again on here, SD14 will hopefully follow soon.
             Regards Howard.
« Reply #368 on: January 26, 2023, 08:19:23 pm »
Hi there Howard, it's brilliant to see you back on the forum and it'll be nice to see your updates when you're back on SD14  :-))
Aye,
« Reply #369 on: January 26, 2023, 09:46:46 pm »
Yes, great to hear from you Howard!   :-))
Howard
« Reply #370 on: January 26, 2023, 11:31:43 pm »
Thank you Martin and Ray
« Reply #371 on: January 27, 2023, 11:49:42 am »
A great build to follow again - I cannot wait - loved waiting for the next update
« Reply #372 on: January 27, 2023, 10:31:05 pm »
Welcome back Howard, just take it easy, health first SD14 later
« Reply #373 on: January 28, 2023, 01:37:18 pm »
Welcome back Howard.
« Reply #374 on: January 28, 2023, 10:29:31 pm »
Good to hear from you again Howard - enjoy the build and keep us updated.
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16   Go Up
