Author Topic: Cyano and water  (Read 2577 times)
Terry
Cyano and water
« on: January 25, 2015, 10:05:27 am »
Is Cyano adhesive OK for areas that occasionally  get wet, ie above the waterline.
Cheers, Terry.
Re: Cyano and water
« Reply #1 on: January 25, 2015, 10:55:18 am »
A good quality one in the medium range should be alright for a few years.  Mind you, it is designed to degrade on human skin.   %)
Can you use epoxy resin. ?  This will last.
radiojoe
Re: Cyano and water
« Reply #2 on: January 25, 2015, 11:21:25 am »
I did a test a couple of years ago, as this question kept coming up, I made a small styrene box about 2" square and 2" deep,  using Admiralty Glues Professional thin cyano and filled it with water and put it on a shelf in the workshop I remembered it 6 weeks later it was still in one piece with water in it, how much more water proof can you get %% %%
Re: Cyano and water
« Reply #3 on: January 25, 2015, 04:58:13 pm »
natural evaporation would empty the vessel, so how did you overcome this? a weighted vessel in water (as this is what the usual test would be for - keeping water out) means it does not matter what the water level is and can be maintained as the water evaporates, any water entering is easy identified.
radiojoe
Re: Cyano and water
« Reply #4 on: January 25, 2015, 06:09:54 pm »
I said it had water in it, obviously some had evaporated, the point is it didn't leak out and the joints were intact, in fact it took some force to break the box apart, so I don't see any difference whether you are keeping water out of a box or in a box the glue in the joints is still being tested %%
morley bill 1
Re: Cyano and water
« Reply #5 on: January 25, 2015, 09:32:55 pm »
hi terry you can glue it with any glue as long as you use a waterproof varnish after....regards bill...
Page created in 0.099 seconds with 22 queries.
