Author Topic: Super glue  (Read 4058 times)
gerard
Super glue
« on: February 15, 2015, 10:07:11 pm »
can anybody suggest anything that will remove dried super glue from UPVC. Didn't realize it was leaking, help!
Gerard
Howard
Re: Super glue
« Reply #1 on: February 15, 2015, 10:41:43 pm »
If Am right you can now get a superglue, deglue never used it but have seen it might be just for skin,
                    regards Howard.
cbr900
  • Mayhem is the Only Forum!
    • Roys Hompage
Re: Super glue
« Reply #2 on: February 15, 2015, 10:47:17 pm »
Mate,
Debonder is the thing you need I spilt some on our lounge and it took it out completely, your model shop should have it or be able to order it..............
Roy
gerard
Re: Super glue
« Reply #3 on: February 15, 2015, 11:04:52 pm »
Thanks for your help, will go and get some to try
Gerard
StarLocAdhesives/FiveStar
    • StarLoc FiveStar quality adhesives and glues at FMK
Re: Super glue
« Reply #4 on: February 16, 2015, 09:16:04 am »
Debonder will often/should attack upvc as the plastic melts at around the same value as cyano, caustic soda  paste is better ( as long as you keep it off your skin ), it takes longer but will work
Formulators and manufacturers of quality adhesives and surface coatings for industrial , DIY & modelling sectors since 1988
See us online   www.shop-4-glue.com
on ebay https://www.ebay.co.uk/sch/gianthairyhedgehog/m.html?_nkw=&_armrs=1&_ipg=&_from=
gerard
Re: Super glue
« Reply #5 on: February 16, 2015, 10:13:36 am »
Thanks for the warning, will try on a spare first.
 Gerard
Brian60
Re: Super glue
« Reply #6 on: February 16, 2015, 01:34:49 pm »
Has the pvc still got its shiny surface? have you spilled the glue on the shiny surface? If so your luck could be in. Take a steel rule or other metal imlement that has a nice clean but blunt edge- like the end of a steel rule. It has to be blunt not a blade edge. Place the blunt edge against your blob of glue as though you were using a chisel. Then tap the other end of the rule with a heavier object.
The glue won't bond to the surface, its too shiny for it to 'grip' so will tap loose. If the surface has been roughened then a debonder will be needed. however these are all based around solvents so will also eat into your substrate as well.
Bob K
  • Bob K
Re: Super glue
« Reply #7 on: February 16, 2015, 01:47:19 pm »
What urgency is required?   ie Removal before wife come home and spots it on settee :D
gerard
Re: Super glue
« Reply #8 on: February 16, 2015, 06:34:42 pm »
No urgency, am going down the caustic soda avenue.
Once again thanks for all your help.
Gerard
henly1234
Re: Super glue
« Reply #9 on: July 21, 2015, 08:59:53 pm »
Acetate, the same stuff that takes off nail varnish but might melt other stuff as well use with caution.
Life is like a child's shirt, Short and full of S**t,
(in remembrance of an old skipper of mine)
