Pages: 1 [2] 3 4 5 6 7   Go Down
Author Topic: Fairmile D lrrc No 040  (Read 58879 times)
inertia
Re: Fairmile D lrrc No 040
« Reply #25 on: May 01, 2015, 06:53:28 pm »
Fair enough, but that battery/motor combination looks more like a narrow boat to me. I've seen more Huntsman models trundling round like canal boats than I care to remember. You read it here.
DM
gra2
« Reply #26 on: May 09, 2015, 10:00:10 am »
Test went well last Sunday more than enough speed at full throttle but I want some endurance as well.
I can install Lipo batts if required I use Lipos in my Dogboat in photo above.
Graham
gra2
« Reply #27 on: June 27, 2015, 07:48:40 am »
 A couple more shots of deck.
Graham
gra2
« Reply #28 on: June 27, 2015, 07:51:09 am »
Last one.
Boat will be running on Lipos.
Graham
« Reply #29 on: June 27, 2015, 07:54:42 am »
Nice Curves!   :-)
« Reply #30 on: June 27, 2015, 10:31:06 am »
There is something about boat modelling in wood. The colours and the way the ply curves, it is a lovely piece Graham:O)
gra2
« Reply #31 on: July 23, 2015, 08:22:34 am »
Hi can anybody tell me which issue of Marine Modelling Magazine carried the article on Roy Skeates Fairmile D build.
I had the Mag and gave it away I am trying to get some detail of the bridge area on the later boats I understand that later boats moved controls from STB to Port.
LRRC 040 that I am building was ex MTB 744.
Gra
gra2
« Reply #32 on: July 24, 2015, 08:31:53 am »
Hi some cabin build.
Graham
gra2
« Reply #33 on: July 24, 2015, 08:35:44 am »
One more.
Graham
MTB Hulls
  • MTB Hulls for Shipshape Models
    • MTB Hulls picture gallery
« Reply #34 on: July 24, 2015, 09:54:45 am »
Wonderful work, I am loving this  :-))
Christian.
http://www.mtbhulls.co.uk/
canabus
« Reply #35 on: July 24, 2015, 12:56:43 pm »
Hi
I am using 3639-1100kv motor with 37mm x 1.4 pitch prop on 5800mah 3S 40C Lipo battery.
I think with the two motors your scale speed will not be a problem.
These motors will run on 4S (14.8 volts) OK, I run one about 10 times in a deep vee with no water cooling.
It only got warm after 1/2 hour of hard run time.
Nice boat and with some one that served on one giving info about the little things that make it prefect.
MTB Hulls
« Reply #36 on: July 24, 2015, 02:10:38 pm »
MTB 718 had her controls on port;
Christian.
« Reply #37 on: July 24, 2015, 08:23:54 pm »
'Ere, don't pull that lever love, it'll excite the engineer' :-)
gra2
« Reply #38 on: August 04, 2015, 08:29:22 am »
G/day a bit more progress.
Graham
spooksgone
« Reply #39 on: August 04, 2015, 03:27:47 pm »
Loving this :-)) I am going to build one next. I need to get a hull first, and intend on using the battle craft fittings. I am not sure what boat it will be, I will have to do some research on the subject, not my usual thing these boats. Thank you for sharing. :-)) Regards. Phil
Perkasaman2
« Reply #40 on: August 04, 2015, 06:41:21 pm »
A great build, looking forward to seeing your work. That is a quality hull. This model will be very impressive in the water when she is complete.
« Reply #41 on: August 04, 2015, 09:48:20 pm »
Lovely progress. I like the ventilators, they add a victorian touch to the boat.
« Reply #42 on: August 12, 2015, 06:54:32 pm »
hello there Graham
I have a photocopy of the Marine Modelling article of the Fairmile D build.   However, it is a very poor copy and every time I try to photocopy the copy it turns out with a black mass - I do though have Model Boats issue June 1976 in which John Pritchard has an article of the Royal Airforce Rescue Launch (the large Fairmile D one) and there are several drawings and a couple of photographs to go with the article.    If you haven't got this article and would like it - can you forward me your email address? and I will scan it and send it to you.
Your model is looking good and look forward to progress report.
aye
MTB Hulls
« Reply #43 on: August 18, 2015, 11:08:15 am »
Roy Skeates' model bridge detail;
Christian.
« Reply #44 on: August 18, 2015, 06:59:14 pm »
Phenominal!
gra2
« Reply #45 on: August 19, 2015, 05:59:56 am »
Hi a bit more work done.
Graham
gra2
« Reply #46 on: August 19, 2015, 06:04:21 am »
Item on r/h of previous photo is a 3d printed 1/24 scale 20mm Oerlikon from Shapeways.
Graham
gra2
« Reply #47 on: August 19, 2015, 06:12:30 am »
Previous photo and this photo of stern 20mm mount.
I need some help with underneath structure of this mount can anybody help please.
I have a photo but it is to dark.
Graham
« Reply #48 on: August 19, 2015, 08:57:13 am »
Hi Graham
Look out for a Email  :-))
aye
john
« Reply #49 on: August 19, 2015, 09:13:44 am »
I have lots of pictures of Roy's Fairmile D if required.   :-)
Pages: 1 [2] 3 4 5 6 7   Go Up
