You will need support for the prop shafts in the hull as well as on the outside, otherwise vibrations will cause a lot of noise in the glass hull and it will sound like a can of nails,I usually make tapered strips of ply and glass them in to support long shafts which cuts out vibrations and noise,I would also fit lubrication points on the shafts as this save the time of taking the shafts apart to oil,Ray.
