Author Topic: Waking Hilda from Hibernation.  (Read 2397 times)
hammer
« on: March 16, 2015, 10:40:18 am »
The Exeter Club lost there lake, in 2013. The new venue it not suitable for sail with on motor. So Hilda has not been used since. Now the sail enthusiast have found suitable place. So Hilda a
3/4 to1 Bristol Channel Pilot Cutter can come out of hibernation. Taken out of the polythene. Plenty of access to the inside I could have installed a motor. But I like the challenge of mastering the wind.  The drum servos are attached to a wooden trough which stop the cables getting tangled. Held by 2 screws it can be removed as a unit.  The rudder servo sits in the centre, receiver just under port trough. Most of the ballast consist of lead chips mixed with cement, no external required. Two strips of wood in the bottom, hold the removable ballast, consisting of a bag of sand.   The hatch is held down with 4 screws. With a rubber seal under the edge.  Now you see it Now you don't.. The cockpit and hatch sealed down semi permanent, by clear bath silicon. More soon. Geoff
hammer
Re: Waking Hilda from Hibernation.
« Reply #1 on: March 16, 2015, 11:30:00 am »
It takes about 10 minutes to fully rig from packed for transport 4'+18"+18" approximately.  Packing up, after loosening the sails.To prevent tangles, the fore sails are raped a round each set of shrouds, held with making tape. Likewise the lines are taped to the mast. The mast is lifted and pulled back laid down with main sail under.
I know the metal fitting should be painted black or green, but with this one I wanted her to look pretty. All the other boats I have built have been as authentic as I could get. All the fittings made by myself from brass. The pulleys brass & cedar, with steel pins.   Hatch opens, inside are the switches one radio the other the masthead light. I must get the dust off & find the lantern.
hammer
« Reply #2 on: March 16, 2015, 12:02:49 pm »
The lantern bracket seen in this photo. Sails by myself bolt ropes stitched by hand, seams by machine.
  Jobs to do before sailing The shrouds need tightening or replacing they are elastic so maybe perished. As is the elastic holding the bowsprit out. One of the mast hoops needs replacing , good thing I already have a spare on the mast at the bottom.  The white packing where the mast enters the deck needs a new piece. Shouldn't take me long.
The chain I didn't make it is jewellery, so could be gold. I always use jewellery chain, as model shop chain links are only pressed together, and will not take any strain.
Hilda is a very good sailor even better than (last pic)the Spray '1/2"to1'  long since sold to make room. This is the normal sailing rig. To reef to main remove a bolt and twist the boom. Sorry the west country reefing gear is only show, don't work.
« Reply #3 on: March 16, 2015, 12:41:48 pm »
Good luck with your new sailing lake. Lovely boat, enjoy!  :-))
