Am I correct in assuming that your question is about full-size practice? If so, the essentials are as follows.
Once vessels became propelled by paddles and then screw propellers which required hull penetration(s), there had to be a means of keeping the water in its proper place outside the hull and supporting the weight of the drive shaft(s) and screws/paddles.
In the case of paddles, this was accomplished by bearing ‘brasses’ either side of the paddles with a packed gland where the shafts penetrated the hull. Where screws are involved, the methods are more various.
Putting it in simple terms and without delving into the realms of shaft liners and rubber seals, single screw vessels use a sterntube through which the tailshaft passes. In earlier designs, the weight of the shaft and screw was taken by staves of lignum vitae (hardwood), dovetailed around the tube and forming a bearing. The for’d end of the sterntube was sealed by a packed gland. The stern tube allowed water ingress at the aft end to lubricate and cool the bearing and usually a seawater feed was arranged to cool and provide lubrication of the gland. A trickle of seawater from the gland into the bilge was the norm and, when this increased, it was a sign the lignum vitae was wearing. (I recall one vessel where the weardown was so excessive that the lateral movement of the tailshaft loosened and then fractured the twelve 1.5” dia. holding-down bolts of the aftermost shaft bearing.)
Later developments involved white metal bearings and oil-filled tubes which obviously had to be sealed from leakage by outer and inner seals. A positive pressure within the tube was provided by a header tank. Still later a combination of old and new resulted in the introduction of synthetic bearing staves.
When multiple shafts are employed, then obviously the shafts are led to port and starboard of the hull to provide clearance for the screws to operate. Up to a point, the support and bearing arrangements mirror those of single-screw vessels and the tailshafts/sterntubes are contained within fairings secured to spectacle frames. For reasons of hydrodynamics and weight, these are not continued all the way to the screws although the fairings usually provide less drag than the ‘P’ or ‘A’ brackets which are employed aft of the stern tube. The shaft support brackets, whether ‘A’ or ‘P’, also locate the shaft, act as bearings and take the weight of the screw. The exposed prop shaft surface exposed to seawater may be protected against corrosion by a paint coating, other surface treatment, sleeves and/or cathodic protection.
Barry M
