I am getting there slowly!
I checked the electrics over and she is ready for her test sail tomorrow. I then decided to start the quarter deck.
I made one from Styrene, but it was a bit flimsy given that it would have mots of details on it and be required to lift off occasionally, so worried that it might shed bits from time to time, I decided to make one from 3.2mm ply. I already had the blank cut out that was to become the deckwale, but decided that this should be styrene so that I could weld it firmly to the hull making a box girder.
The camber was created with the Japanese file and sandpaper. It was then painted with several layers of thinned dope and a neat layer.
The superstructure was made from 1mm styrene with internal supports to strengthen it and then pieces of 6mm ply were epoxied in for two reasons.
1. To provide places where glue could be applied to help fix the superstructure to the deck.
2. To provide places to drill through and mount things like the mast and also a combination Torpedo tube mount/deck fastner.
A small section of the deck was cut off and glued to the hull along with a section of the superstructure that was filled with ply and glued to the deck.
Once cured, the deck was put in place and the superstructure glued onto it matching with the small section forward.
You can see the section of deck now clad in .25m styrene representing the deck covering, which while not haphazard, was certainly added in large patches which will be represented on the deck.
More soon
