Etronix 60T, ET0313. Available from all good CML Distribution stockists.
Just got two of these in for a Darnell/Models By Design/Mountfleet* Type VII U-Boat. Dont like the MFA RE540-1, too sparky, Johnson 600s only good for fast set ups or with big reduction gearboxes, and Graupner have stopped doing anything useful!
So these motors are designed for Rock Crawlers hence the 60T, which indicates the number of turns of copper around the armature, the more turns the slower the motor. As a guide the old Chart/Micromold RS550 had 32 winds, and a typical buggy motor ( of the time! ) had a 27 turns, they are now more typically 15 to 20 turns, don't put these in your fishing boats please!
Got one out of the pack today, very high torque, 1 amp off load and between 2.5 and 3 amps on load. Scientifically proved by running the motor shaft hard against a piece of timber till it slows down about as much as you would expect with a prop on it!!
I think the 60 Turn motor could turn a 45mm prop direct drive, at a push and at about 3 to 3.5 amps. Smaller prop, lower current.
All for £16.99.
Cheap Chinese versions available from the usually sources!
* Mountfleet do a most excellent late conning tower for the Type VII with the extended AA platform, nice...
