Author Topic: Distribution board  (Read 3327 times)
Buster22
Distribution board
« on: April 12, 2015, 04:26:36 PM »
I need  Some kind of board that I can connect 2 different battery voltages coming in 6v 12v and then send out to the different equipment like mixer 6v and lighting 12v deck winch esc 12v  would like 1 board as limited for space thanks for the help
inertia
Re: Distribution board
« Reply #1 on: April 12, 2015, 05:58:44 PM »
This is the only product I know of which will do what you need. Its supply is just one voltage because it has regulators to reduce that to the other (lower) ones. Do pay attention to the maximum current loadings, however.
http://www.harbormodels.com/site08/main_pages/power_distribution_panel.htm
DM
Buster22
« Reply #2 on: April 12, 2015, 06:11:37 PM »
Yeah know about that one just too big for the space available
Buster22
« Reply #4 on: April 12, 2015, 07:18:44 PM »
Would prefer something with screw terminals
« Reply #5 on: April 14, 2015, 09:38:03 AM »
The first board linked to "looks" like it "might" accept standard size screw terminal strips for PCBs, but that's a guess because no dimensions are given.  Adds bulk and unreliability, but then screw terminals, compactness and reliability in an environment with movement don't usually go together.
If its just distribution that is wanted, screw terminal strips are available in most hardware stores, just use one side to loop the chosen groups of terminals and the other side for inputs and outputs.  Keep the ground line solid and simple, make sure that the different voltage groups stay separate.
inertia
« Reply #6 on: April 14, 2015, 09:53:31 AM »
I'd go anywhere for a "100% satifiation service" (2nd E-Bay item). I wonder which two words collided to make that one? It looks like something George "Dubya" might have said!
DM
« Reply #7 on: April 15, 2015, 10:07:25 AM »
DM
I wonder what Mick Jagger would have rhymed it with?  "I can't get no satifiation"
boman
« Reply #8 on: April 17, 2015, 11:57:38 PM »
What Dimensions are you looking at?
Buster22
« Reply #9 on: April 18, 2015, 04:36:33 PM »
About 3 inch by 3 inch
boman
« Reply #10 on: April 18, 2015, 10:39:46 PM »
Can you make one? I made one out of a plastic box that I bought from an electrical supply store. Mine measured 65 x 115 but they had multiple sizes in stock. I drew up mu own wiring diagram and went with that. I have 7.5v and 6v coming in, and being split into the various factions that I need.
I have supplied my wiring diagram as an example.
Buster22
« Reply #11 on: April 19, 2015, 01:16:33 AM »
Sorry but not that good
boman
« Reply #12 on: April 19, 2015, 05:14:00 AM »
Neither am I. But it was the only way to get exactly what I needed.
beagle-01
    • beagle's modelships
« Reply #13 on: April 22, 2015, 08:33:51 AM »
Ship modelling is not a hobby, it has become a way of live. Brian King.
Als je ouder wordt, wordt alles slechter, behalve het vergeten, dat wordt steeds beter ...
Grtz Erik
