Author Topic: Milling tools  (Read 4889 times)
Brian60
Milling tools
« on: April 29, 2015, 06:54:04 am »
I'm in need of a 0.5mm slotting mill with a 3mm shaft. Does anyone have a company that sells them apart from Dremel!
TugCowboy
Re: Milling tools
« Reply #1 on: April 29, 2015, 09:39:26 am »
 Not especially cheap but these guys sell quality kit:
http://www.shop-apt.co.uk/
Brian60
Re: Milling tools
« Reply #2 on: April 29, 2015, 01:44:47 pm »
Thanks for the link. The shafts are 4mm not 3mm but I think I can get a holder for that. £8.40 plus p&p, I'll get one on order.
nemesis
Re: Milling tools
« Reply #3 on: May 05, 2015, 08:07:40 pm »
Hi, Have you tried Tracy Tools, I find that they are excellent. Nemesis
bfgstew
  • Comfortably Numb
Re: Milling tools
« Reply #4 on: July 03, 2015, 02:48:02 am »
Maybe a bit late Brian, but try these guys. - https://cnc-plus.de/index.php
"Give me a ping Vasili. One ping only, please"
Southern Sailor
  • Southern Sailor
Re: Milling tools
« Reply #5 on: July 03, 2015, 08:59:35 am »
Hi Guys.  This is a bit off the subject but the topic fits.  I am considering buying a Proxxon dividing head but it is for a different compound table to that which I have.  I have the KT 150 table and the head in question is for the Proxxon micro miller.  I am thinking of buying the head but using an aluminium adapter plate to be able to mount the head on my compound table.  Any comments?  Thanks. Brian
Re: Milling tools
« Reply #6 on: July 03, 2015, 10:02:48 am »
Evening Brian.........I am very interested to understand more with your progress with [Proxxon :-)) ] components ... Derek
Southern Sailor
  • Southern Sailor
Re: Milling tools
« Reply #7 on: July 03, 2015, 07:33:35 pm »
Hi Derek.  I will keep you posted.  The self-centering vices that have been referred to on the CNC PLus website look worth considering. Brian
Southern Sailor
  • Southern Sailor
Re: Milling tools
« Reply #8 on: July 19, 2015, 06:10:19 pm »
Hi Derek.  I have sketched the proposed adapter that I have in mind and attach it here. The two questions I have are how to harden the surface of the adapter plate (also is that necessary?) and is aluminium strong enough?  I have received a vague reply on these questions from the local SA agent and may go direct to Proxxon for their comments.  Will keep you posted.  Brian
thething84
Re: Milling tools
« Reply #9 on: July 30, 2015, 02:32:05 am »
Brian it would depend on what Aluminium you make it out of. Comercial aluminium is soft. But get a decent grade of aircraft ally and it should hold up fine. We use a baseplate on all our CNC machines at work which is a series of tapped and Reamed holes to suit caphead and dowels for location. They are all made of aluminium and still going strong. James
If it ain't broke! Fix it anyway!
Southern Sailor
  • Southern Sailor
Re: Milling tools
« Reply #10 on: July 30, 2015, 05:42:55 am »
Thanks James.  That is such an encouragement, and if I can find aircraft alli down south here I will certainly use it. Will keep you posted. Brian
thething84
Re: Milling tools
« Reply #11 on: July 30, 2015, 01:24:32 pm »
Ahhh just looked at your location. If ur careful with it wven comercial will do it. Just its easily dented and scratches easily due to its softness
Southern Sailor
  • Southern Sailor
Re: Milling tools
« Reply #12 on: August 01, 2015, 06:23:01 pm »
By the way, as a matter of interest, is there anyone out there who has actually used the Prox24264 dividing head? I would be grateful for comments on this tool.  Thanks. Brian
Page created in 0.982 seconds with 16 queries.
