Author Topic: planet T7 binding problems  (Read 6488 times)
ian-mccaffrey
  • roll on mayhem at wicksteed 2016 !
« on: May 11, 2015, 08:23:33 pm »
can any one tell me how to bind this thing before it goes out of the window please
lets just hope this one floats !!
fire at will ! ... which one is will ?
Bob K
  • Bob K
Re: planet T7 binding problems
« Reply #1 on: May 11, 2015, 08:34:14 pm »
Ian:  This is copied straight from my Planet Transmitter Manual.  I hope it is helpful.
BINDING TRANSMITTER TO RECEIVER
A working 2.4Ghz transmitter and receiver have a coded, 'bound' relationship with each other. The setting up of
this relationship is known as 'binding'.
In a 'bound' transmitter/receiver relationship the receiver is exclusively bound to your transmitter and can only
respond to signals received from that transmitter. It will not respond to any other device or transmitter.
Once a transmitter is bound to it's receiver, re-binding of transmitter and receiver is not normally required.
However, by binding your receiver, for example, to a friend's Planet 7 transmitter, the unique relationship between
your original transmitter and receiver will be broken. Should you wish to - or need to, re-establish or 'bind' your
transmitter with your receiver once more; proceed as follows:
HOW DO I RECOGNISE WHEN MY RECEIVER IS NOT BOUND?
Upon connecting the battery in the model the receiver status indicator LED will flash on and off slowly regardless
of whether the transmitter is switched on or not. Even when the transmitter is switched on; no control or change
in the slow flash of the LED will be seen.
HOW DO I BIND RECEIVER AND TRANSMITTER?
▼ 1. Switch off the transmitter.
▼ 2. Connect receiver battery. Press the binding microswitch on the receiver undersurface briefly once with
your fingernail or a small screwdriver.
▼ 3. The receiver status indicator will flash in groups of three.
Binding LED
flashing in threes
▼ 4. Switch on the transmitter.
As the signals are acquired, the Binding LED will flash briefly and then glow solidly a few seconds later
indicating a successful binding.
▼ 5. Operate your model as normal. The Binding LED glows solidly once bound with the transmitter.
ian-mccaffrey
« Reply #2 on: May 11, 2015, 08:35:53 pm »
thank you bob . ill try it in a minute ! . thats the part i had missing in my box ... joys of second hand goods !
ian-mccaffrey
« Reply #3 on: May 11, 2015, 09:10:22 pm »
nope . dont work bob ... the receiver i have has a hard case . but no binding button like the soft cases have
bigfoot
« Reply #4 on: May 11, 2015, 09:42:54 pm »
Try" Planet T7 review -J Perkins Distributor" on Google
There is a paragraph in there telling us how to bind our sets.
Good luck
mrturbo553
    • North Sea winches
« Reply #5 on: May 11, 2015, 09:51:42 pm »
Ian isn't the binding micro switch in the same spot as the soft cased ones ?
http://www.rctankregiment.com/rctankforum/download/file.php?id=3421
Aid
Gone racing back in 9.5 sec
http://www.nswinches.co.uk
ian-mccaffrey
« Reply #6 on: May 11, 2015, 09:56:11 pm »
Aid
no its not there
Klunk
« Reply #7 on: May 11, 2015, 10:09:37 pm »
Going to state the obvious here. But I always bind with a receiver battery connected directly to the rx. I take it that one of the leads going into your rx is a power lead as the picture is not that clear
full time penguin
mrturbo553
    • North Sea winches
« Reply #8 on: May 11, 2015, 10:23:06 pm »
http://www.airtekhobbies.com/planetsystems.html
Ian go to the bottom of the page there's a hard cased one with what's looks like a small slot where the micro switch is ?
Aid
ian-mccaffrey
« Reply #9 on: May 11, 2015, 10:23:27 pm »
panic over ..... remind me to put my glasses on next time im looking for a binding button !  >>:-(
U-33
  • K-157 Vepr. Akula-11
« Reply #10 on: May 12, 2015, 09:08:49 am »
You'll have to excuse him, people..shoulda gone to Specsavers.  %)
« Reply #11 on: May 12, 2015, 02:43:46 pm »
Not got one in Milford Haven where Ian resides <*< <*<
