Author Topic: Broken connection  (Read 2765 times)
stickystuff
  • Work, curse of the drinking classes
Broken connection
« on: May 19, 2015, 08:57:29 pm »
I have just managed to sheer off completely one of the electrical connections on a brand new bow thruster motor.Is this repairable and if so please point me in the direction
If at first you don't succeed do something else and try again later
Re: Broken connection
« Reply #1 on: May 19, 2015, 09:06:16 pm »
A Picture would help to decide what to do next,in regards to help you
stickystuff
« Reply #2 on: May 19, 2015, 09:31:53 pm »
I will take one and post on here tomorrow, if I can find out how
« Reply #3 on: May 20, 2015, 09:38:39 am »
If all that is visible is the cross section of the tag flush with the plastic of the end cap, the chances are slender.  A repair would involve tinning the bare metal using solder paint and a very hot iron with a very small tip so as to get in and out before seriously damaging the plastic end cap.  A workable procedure might be to use the leg of a suppression capacitor with a longer wire pre-attached as a new tag.
To get to the tag to do a replacement would probably involve removing the cap from the body - small motors are generally not designed to be disassembled and reassembled.  It can be done with care, ingenuity and patience, but good results are not common.  The tabs holding the end cap in place either refuse to bend straight or go back where they came from, and the sprung brushes give their on problems.
inertia
« Reply #4 on: May 20, 2015, 12:53:14 pm »
It might be easier to replace the motor. A stock 380 will fit Graupner, Raboesch and Robbe units and run on 6v to 7.2v. If you want to use a 12v supply then fit a 385. Either type should cost you no more than a fiver.
DM
« Reply #5 on: May 20, 2015, 02:18:07 pm »
Good lateral thing Mr M
« Reply #6 on: May 20, 2015, 04:18:23 pm »
..........and probably cheaper than a bottle of solder paint as well as having a more certain outcome.
unbuiltnautilus
« Reply #7 on: May 20, 2015, 05:57:24 pm »
bad news, its smaller than a 280 motor, with a 2mm shaft..good news, I've fixed it. With the usual lack of fan fair and tub thumping..extensive series of posts to follow explaining how talented, modest, under appreciated etc etc................
 ok2
stickystuff
« Reply #8 on: May 20, 2015, 08:52:45 pm »
Thank you kind sir , I will thump any tub loud and long and shout your prowess from whatever rooftop you point me towards, provided a strong ladder is available.   :}
stickystuff
« Reply #9 on: May 20, 2015, 09:01:03 pm »
Now fixed - thanks for your interest
Page created in 0.104 seconds with 22 queries.
