April 25, 2024, 07:53:22 am
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Mayhem at Wicksteed -
May 25, 26
Home
Help
Search
Calendar
Login
Register
Mess Deck: General Section
Chit-Chat
How do drill glass
« previous
next »
Pages: [
1
Go Down
Print
Author
Topic: How do drill glass (Read 4258 times)
Klunk
Global Moderator
Full Mayhemer
Offline
If you know who I am, please remind me!!
luton, beds
How do drill glass
on:
May 28, 2015, 06:06:43 pm »
As in the title. I need to drill a round hole in a large glass bottle. How do I do this apart from carefully! Special drill bits etc
full time penguin
Howard
Full Mayhemer
Offline
Scotter Lincolnshire
Re: How do drill glass
Reply #1 on:
May 28, 2015, 06:18:44 pm »
You will need whats called a spear head drill and If am right a ring of putty and some white sprit.
Regards Howard.
Full Mayhemer
Offline
Meridian Line, Mouth of the Humber
Reply #2 on:
May 28, 2015, 06:24:12 pm »
And go slow.
Blue tack or putty for the cofferdam.
Up Spirits Stand fast the Holy Ghost.
david48
Full Mayhemer
Offline
Strathdon,Aberdeenshire
Reply #3 on:
May 28, 2015, 06:24:30 pm »
What size hole .If I remember dermal used to do a glass engraving wheel .have a look on Toolstation I have just bought a drill for ceramic /hard porcelain it worked perfect .It says it will drill glass ,not tried that .David
Two heads are better than one sheep head as my old plant manager used to say
gingyer
Full Mayhemer
Offline
Glasgow
Reply #4 on:
May 28, 2015, 06:31:53 pm »
Get someone else to do it
They take the blame when it goes wrong
Klunk
Global Moderator
Full Mayhemer
Offline
luton, beds
Reply #5 on:
May 28, 2015, 06:37:34 pm »
It's a 14mm hole
full time penguin
sparkey
Full Mayhemer
Offline
I think I am as mad as I think I am then I am mad
wandsworth
Reply #6 on:
May 28, 2015, 06:46:34 pm »
You can get drill bits for glass from Screwfix I know I get some to drill mirror,works O.K. just don't use too much pressure,Ray.
Global Moderator
Full Mayhemer
Offline
You bark - I will bite!!!
Fareham
Reply #7 on:
May 28, 2015, 07:41:45 pm »
Is it a flat bottle, like a gin bottle or a round bottle like a wine bottle?
GAZOU
Full Mayhemer
Offline
Model Boat Mayhem is Great!
ROCHEFORT FRANCE
Reply #8 on:
May 28, 2015, 08:15:12 pm »
To remove the cork is a good thing
Brian60
Full Mayhemer
Offline
Hull,UK-but currently residing in Los Martinez, Spain.
Reply #9 on:
May 28, 2015, 08:28:35 pm »
Also fill it with water and cork the end. This will damp out any vibrations.
http://www.modelboatmayhem.co.uk/forum/index.php/topic,46369.0.html
Humber Trawler
http://www.modelboatmayhem.co.uk/forum/index.php/topic,49047.0.html
POSH Venture
http://www.modelboatmayhem.co.uk/forum/index.php/topic,53834.0.html
Tramp Steamer
Klunk
Global Moderator
Full Mayhemer
Offline
luton, beds
Reply #10 on:
May 28, 2015, 08:31:53 pm »
Large round bottle. Ie teachers whiskey pub size
full time penguin
Global Moderator
Full Mayhemer
Offline
Fareham
Reply #11 on:
May 28, 2015, 08:52:42 pm »
You do know it will drill an elipse in the glass.
Klunk
Global Moderator
Full Mayhemer
Offline
luton, beds
Reply #12 on:
May 28, 2015, 09:18:57 pm »
Yep that's not a problem. It's having another tube attached to it for an experiment.
full time penguin
J.beazley
Full Mayhemer
Offline
The building never ends
Locks Heath, Hampshire
Reply #13 on:
May 28, 2015, 10:11:58 pm »
It's not going to be easy that's for sure.
I've drilled many glass fish tanks of various thickness glass upto 28mm thick you just have to take it slowly and use plenty of water as you drill to reduce heat build up which will cause cracks or chips.
Helps having a decent drill with adjustable setting of rpm.
Jay
Umi_Ryuzuki
Full Mayhemer
Offline
PDX, OR USA
Reply #14 on:
May 28, 2015, 11:10:58 pm »
Could you use a stopper with holes in it like a lab?
Models and Miniatures
thething84
Full Mayhemer
Offline
Newmarket, Suffolk
Reply #15 on:
May 29, 2015, 01:24:26 am »
I drill two holes in a fish tank using a glass diamond coated drill. Cut bueatifully. Apply no pressure to the drill just let it do the work itself. I made up a little piece of wood to hold the drill in place till its started cutting its groove. As said create a dam around it and keep a flow of water on it.
This is what i used.
http://www.ebay.co.uk/itm/DIAMOND-HOLE-SAW-4mm-125mm-Tile-Ceramic-Porcelain-Glass-Marble-Drill-Bit-Cutter-/201159703385?pt=LH_DefaultDomain_3&var=500326903373&hash=item2ed60d7b59
James
If it ain't broke! Fix it anyway!
Print
Pages: [
1
Go Up
« previous
next »
Chit-Chat
How do drill glass
