Pages: 1 [2] 3 4 5 6 7 8 9 10 11   Go Down
Author Topic: 1/48 Hunt Class MCMV HMS Quorn Build log  (Read 63770 times)
Z750Jay
Re: 1/48 Hunt Class MCMV HMS Quorn Build log
« Reply #25 on: June 05, 2015, 05:58:49 pm »
Oh yes. Cramped us the word
Jerry C
« Reply #26 on: June 05, 2015, 06:44:42 pm »
No major work done on board. Engines just exchanged. Quite quickly too.
Jerry.
T888
« Reply #27 on: June 07, 2015, 12:31:03 pm »
Cast off the 30mm gun kit from the masters for Clyde & Penzance last night. Also made the doors, satcom and the rudders.
Not too happy with the doors, so may remake them later.
Regards Dave
In Build ..... USS Roosevelt DDG-80
South Coast Modeller Event organiser
« Reply #28 on: June 07, 2015, 02:37:07 pm »
The gun looks brilliant! It is impressive how the 30mm cannon (itself not a small gun) is dwarfed by all the gubbins around it on the mounting.
Keep up the good work:O)
T888
« Reply #29 on: July 17, 2015, 02:39:23 pm »
Hi ,
Progress is slow due to recovering from a opp on my arm.
What I have done to date is rubbed the hull down with a fine wet & dry grit paper, then sprayed it with a filler primer which is then cut back. once I'm happy with the finish the hull is sprayed with a red primer. Again this is cut back using a fine grade paper, then the under water line is marked and the area above masked off so the lower half can be sprayed with a satin vanish.
« Last Edit: July 17, 2015, 02:44:13 pm by T888 »
Regards Dave
« Reply #30 on: July 17, 2015, 08:01:47 pm »
I wish you a full and speedy recovery from your Op. The sanding should give you some essential physio on your arm muscles.
T888
« Reply #31 on: July 17, 2015, 08:10:34 pm »
Thanks, recovery well under way , it's been hard sanding using only one arm and not being able to do modelling , even when I've been to the SWA shows , had to rely on others to lift my models . hopefully will be able to get back to work next week. Also get some modelling done.
Regards Dave
T888
« Reply #32 on: July 24, 2015, 04:12:14 pm »
Hi all
Been making some fittings for moulding later.
Regards Dave
« Reply #33 on: July 24, 2015, 08:24:40 pm »
Good and crisp. they should reproduce well in resin.
T888
« Reply #34 on: August 03, 2015, 02:40:47 pm »
Hi, it's been a bit of time but some progress had been made
Regards Dave
radiojoe
« Reply #35 on: August 03, 2015, 03:27:56 pm »
Your cracking on with her Dave, I do like the 30 mm. I've only made the cradle for mine, but I did intend it to be a winter build, looking good mate, see you Sunday.  :-))
T888
« Reply #36 on: August 03, 2015, 05:42:16 pm »
Thanks Joe,
The 30 mm is one of my owner moulding kits.
It will be along time before she gets her feet wet, I've still have a lot of the electronics to install. I also plan to have the bridge fully detailed, with a removable roof , so when she at SWA shows the public can see it.
Sound like your winter project is already under way !
Regards Dave
« Reply #37 on: August 03, 2015, 05:48:56 pm »
The danger zone around the 30mm looks brilliant - is it painted in situ ?
T888
« Reply #38 on: August 03, 2015, 05:54:46 pm »
Thanks Ray,
Its done by using yellow solar film, which I cut the circle out using a compass cutter, then the black is painted on.
Regards Dave
« Reply #39 on: August 03, 2015, 08:52:06 pm »
Darned fine!
T888
« Reply #40 on: August 03, 2015, 08:53:35 pm »
Well thank you !
Regards Dave
« Reply #41 on: August 04, 2015, 09:50:23 pm »
My pleasure sir. (Bows and wiggles hat theatrically:O)
Serously though, those sort of markings horrify me. I can just paint stars on US military models but multi coloured rings that are rouns and symetrical, that is an achievement.
T888
« Reply #42 on: October 23, 2015, 04:05:45 pm »
Can any one help me.
I've been trying to upload some picture to my HMS Quorn build log, and error keep saying . can load JPEG as I've already loaded pictures in this format in the past ,can you advise why it's not allowing them now.
I've tried sending Martin a pm but this seem not to be working
Regards Dave
« Reply #43 on: October 23, 2015, 05:07:31 pm »
J pegs are allowed/  maybe they are over 100k in size.  Might need reducing.
T888
« Reply #44 on: October 23, 2015, 05:10:12 pm »
Hi Ken,
Been there don't that still no joy
Regards Dave
« Reply #45 on: October 23, 2015, 08:15:59 pm »
Are you clicking on the attachments section and choosing your  (reduced in size) picture from your computer  ?
T888
« Reply #46 on: October 23, 2015, 10:51:41 pm »
Yes, I've even reduce the size below the min
Regards Dave
T888
« Reply #47 on: October 23, 2015, 10:59:40 pm »
Ken this is the error i'm getting
[size=0.85em]October 23, 2015, 10:56:14 PM[/size]
Total time logged in: 5 days, 6 hours and 38 minutes
[/color] [/size]
[/size][size=0.85em]News:
[/size]Mayhem now also on  FaceBook! [size=0.85em][/url]
[/size]HOME[/size][size=0.85em][/font]
[/size]
  • [/color]HELP[/color][/size][size=0.85em]
  • [/color][/size]SEARCH
  • [/color][/size]PROFILE
  • [/color][/size]MESSAGES
  • [/color][/size]CALENDAR
  • [/color][/size]MEMBERS
  • [/color][/size]LOGOUT
[/color][/size]Model Boat Mayhem - Forum >[/size]Dry Dock / Shipyard: Builds & Questions >[/size]Warships - Navy - Military:[/size][/font][/size]An Error Has Occurred!
image.jpeg.
You cannot upload that type of file. The only allowed extensions are txt,doc,jpg,gif,pdf,PNG,JPG.
[size=0.85em][/size][/size]
[size=0.85em]SMF 2.0.11 | SMF 2011, Simple Machines[/font][/size][/font][/size][/size]
[size=0.85em][size=0.85em][/size]
[size=0.85em]XHTML[/font][/size][/size]
[size=0.85em] [/size]
[size=0.85em]RSS[/font][/size][/size]
[size=0.85em]WAP2[/font][/size][/size]
[size=0.85em]
« Last Edit: October 24, 2015, 10:33:41 am by Tug-Kenny »
Regards Dave
« Reply #48 on: October 24, 2015, 10:38:12 am »
You are getting a computer model clash  methinks.  A bit beyond my technology.  Is it an  Ipod type thingy or tablet  ?   Can you try an old type desktop machine.  ?
T888
« Reply #49 on: October 24, 2015, 01:36:35 pm »
Hi, Ken,
Thanks for the help, yes I'm using an iPad . But all the past posting have been made using the same iPad.
As we don't own a normal computer , it looks as I may not be posting any picture.
Regards Dave
Pages: 1 [2] 3 4 5 6 7 8 9 10 11   Go Up
