Author Topic: Action P50A ....  (Read 3657 times)
Bryan - G4CVF
Action P50A ....
« on: June 14, 2015, 04:39:36 PM »
Hi - I have one of these units which I removed from a model boat some time ago but I can not remember what its function is. Looking at it and the board connections I think it is a small speed controller but I would like to know if this is correct and what its specifications are. Can some one point me towards a spec sheet for it please?
Thanks - Bryan
plug
Re: Action P50A ....
« Reply #1 on: June 14, 2015, 04:48:13 PM »
Google " component shop " and all the action stuff is on there
regards Jack.
Bryan - G4CVF
« Reply #2 on: June 14, 2015, 05:11:00 PM »
Hi Jack - double checked the "Component Shop" just in case I had missed it but they list all current products which unfortunately does not include the P50A. Could not find any historical data.
Regards - Bryan
plug
« Reply #3 on: June 14, 2015, 05:27:24 PM »
Hi Bryan, sorry I thought they had all the Action stuff, there is a member on here " inertia " if he spots this thread he'll probably will advise you or send him a pm
regards Jack.
inertia
« Reply #4 on: June 14, 2015, 05:33:22 PM »
Can you post a picture of it (preferably out of its case)? That might give me a clue. I have no details of it at all; it certainly wasn't in current production when we took over ACTion from Craig in 2007. Don't bother contacting CompShop - they have only the information I sent them, and P50A wasn't included.
DM
Bryan - G4CVF
« Reply #5 on: June 14, 2015, 07:35:10 PM »
Hi DM,
Having taken the device out if it's box I now think it is a Switcher of some sort. The Pic is a 12C508A, the power transistor is a TIP55 and the relay looks to be rated at few amps DC - switching current limited by the size of the pub tracks? Should be a couple of pictures attached.
Many thanks - Bryan
Bryan - G4CVF
« Reply #6 on: June 14, 2015, 07:36:34 PM »
Let's try that again - hopefully with a different picture this time!
Stan
« Reply #7 on: June 14, 2015, 08:14:08 PM »
HI Guys I have lot of old info sheets from Action will check see if I can help. This looks more like a speedo than a switcher unit.
Stan. :(( :(( :(( :(( :(( :((
« Reply #8 on: June 14, 2015, 08:52:43 PM »
Looking at the PCB layout, the relay would be a DPDT type, and reverses the power to the two unwired terminals.  It is probably operated by the small transistor and uses the receiver power to operate.  If plugged into a powered RX, working the appropriate stick should result in the relay clicking around center.
Stan
« Reply #9 on: June 14, 2015, 08:54:06 PM »
HI This is a speedo dating back to Craig Talbot's time. The circuit is a Commander 5 MicroComputer speed controller rated at 5 amps . I have the full info sheet I you would like a copy please Pm your contact details and I will scan and send on.
Stan Reffin
Kirklees Model Boat Club.
Before. :(( :(( :(( :(( :((Now :-)) :-)) :-)) :-)) :-)) :-))
Stan
« Reply #10 on: June 14, 2015, 09:08:06 PM »
HI Guys info sheets scanned and placed on MAYHEM.
Stan
Bryan - G4CVF
« Reply #11 on: June 14, 2015, 09:52:15 PM »
Many thanks Stan. I can remember sending an order to the Biggleswade address for this kit and I can remember building it. I can not, however, remember which model boat I put it in and subsequently took it out of. The really embarrassing thing is that I probably still have the boat - I tend to hang on to my models far too long!
Bryan
inertia
« Reply #12 on: June 14, 2015, 11:10:29 PM »
Thanks, Stan. I should have known you'd have something on it.
Dave M
Tug-Kenny
« Reply #13 on: June 15, 2015, 11:04:03 AM »
Thanks from me also Stan.    :-))
I have this unit and worked out the design some time ago.  A chip controls the small transistor to control a large switcher transistor, and a relay reverses the process to go in reverse.
Mine has failed circuit components which I couldn't identify.  I'll have another go now and see if I can get it working.  Cheers   :}
inertia
« Reply #14 on: June 15, 2015, 12:56:05 PM »
Ken
Now that Stan has turned up trumps with the instruction sheet I remember that "Commander" was Craig's first range of speed controllers using PIC chips, after the demise of the ZN409 I/C. These were high-frequency units and some customers didn't like the high-pitched squeal from the motor at low revs, so the programming was changed to make it low frequency. The new range was the "Condor"; I've no idea why he chose that name - he smoked cigarettes!
I still have some of those 8A DPDT relays and 4MHz crystals in stock but not the semiconductors. If the PIC is shot then it's a bin job, I'm afraid, as the source code belongs to the guy who wrote the software.
Dave M
Tug-Kenny
« Reply #15 on: June 15, 2015, 08:05:58 PM »
Thank you for the input Dave.
According to my  'Scope'  the adjustable wave pattern from the  Pic  Chip has reduced to minimal peak and therefore I have to agree with you and scrap it.
I now have some super  AcTion gear and will  be using it in my Seabex One.
ps.  The solder you sold me years ago is still going strong.  loads left.   :}
