Author Topic: its my RESCUE DINGHIE...  (Read 5961 times)
Krishna
  • aqua plannerrrr....................
« on: June 21, 2015, 07:05:39 am »
a simple build.. based on my lake cat hull.. cut about 1 cms to down to attain a shallow hull.. then glued rubber foam tube that we used to seal split A/C duct pipes.. as it may shrik with NC and PU paints, i just coated the tubing with white glue.. then easy.. powered by a low profile brush less motor, she is so powerful, and weighs only 350 grams.. without battery.. and very responsive..
in sheer ecstasy of being a powerful,mushy,masculine trans woman of substance...
Krishna
Re: its my RESCUE DINGHIE...
« Reply #1 on: June 21, 2015, 07:08:09 am »
on..
Krishna
« Reply #2 on: June 21, 2015, 07:10:15 am »
and on..
Krishna
« Reply #3 on: June 21, 2015, 07:11:34 am »
and..
Krishna
« Reply #4 on: June 21, 2015, 07:12:31 am »
NobbySideways
  • Fairey Huntsman 31 Build in progress
« Reply #5 on: June 23, 2015, 12:52:47 pm »
I love how well hidden all the components are, nice one
TugCowboy
« Reply #6 on: June 23, 2015, 04:18:41 pm »
Looks fantastic and goes well. Nice job Krishna.
Krishna
« Reply #7 on: June 24, 2015, 10:07:37 am »
yes she is beautiful.. and lovely.. thank you Friends..
Mad Scientist
« Reply #8 on: June 24, 2015, 09:17:58 pm »
Using the 'dummy' outboard as a rudder is such a great idea! - Tom
Krishna
« Reply #9 on: June 25, 2015, 07:01:45 am »
keeping drive train simple and reliable as possible.. thank you..
imsinking
« Reply #10 on: June 25, 2015, 09:52:14 am »
You have mastered the art of using brushless motors , do you prefer Out runners ?
What Batteries are you using ? LIPO or NiHm ?
Bill
Krishna
« Reply #11 on: June 27, 2015, 07:49:19 am »
yes.. sure.. brush less motors are so great.. and sure out runners as it can generate more torque, because of the leverage of the cup.. and so easy to make water cooling jackets.. great power to weight ratio.. strain free working at all throttle levels.. easy to install.. can even fix directly under water.. and in all batteries.. but mostly on LiPoly.. great power from little battery packs.. thank you..
Page created in 0.013 seconds with 20 queries.
