In regards to the Wickes varnish, well to be perfectly honest I cant tell the difference between this and polyc. Both dry in similar time and both seems to have same hardness, that said though I also experimented with thinned pva and also thinned aliphatic glue both of which gave a harder but I suspect more brittle finish. None of them however come close to epoxy though which seems hard but resilient. The only trouble is I cant work with epoxy or cyano
Graham pointed out that you need to prime the balsa, I noticed on youtube that polyc recommend you coat the balsa with a coat of polyc, let it dry and sand then cloth and polyc. Tried this with all products used so used wickes varnish as a primer followed by wickes varnish and cloth, so on so forth.
One thing I didn't try was sanding sealer, cloth and dope. But recall back in the day covering flying wing control line models with nylon and dope, this was a good finish and hardwearing, however shrinkage can be a problem. As stated originally cost and actually buying dope, nylon, thinners and sanding sealer is cost prohibitive and difficult in our area to get, most shops wont send by post either.
I have asked Graham to clarify what to prime wood with.
