Author Topic: Futaba 6EX 2.4  (Read 2819 times)
Futaba 6EX 2.4
« on: July 13, 2015, 04:26:19 pm »
Got a little problem which I can fathom out............Model no 4 I seem to have lost any outrput to channel 1 the rudder channel
 ....All the other model modes work as they should.....Ive tried it on the bench with new servos and tried another receiver it is the same as in the actual model and swapped all the servos around and all 4 show the same fault ....NO rudder on the right stick
I have checked that all the other mixing modes are all switched off as I dont use in house mixing.......anyone else had this problem.....obviously if the same was happening to all the Modle modes I would say it is a gimball fault unless I am missing something
Re: Futaba 6EX 2.4
« Reply #1 on: July 13, 2015, 07:38:48 pm »
SORTED
Re: Futaba 6EX 2.4
« Reply #2 on: July 13, 2015, 07:52:30 pm »
I wonder what it was ............................... {-)  {-)
ken
inertia
Re: Futaba 6EX 2.4
« Reply #3 on: July 13, 2015, 08:20:43 pm »
'Welsh electricity' then, Dave............ ok2
DM
Re: Futaba 6EX 2.4
« Reply #4 on: July 13, 2015, 08:26:51 pm »
Very odd one Dave...checked that all hte mixes etc were switched off and it still was the same.........zeroed every setting still the same.........went back to the Mixes and put everything on....still the  same....switched them all off one by one and it worked and is still working....so went back and switched all mixes on and the darned thing still works.....so switched everything off again and it still is working so Dont exactly know what went on. {-) {-) {-) {-)  as you say Welsh electricity  O0 {-)
