Not such a bad idea (despite the weight of the motor), I have no datasheet of the motors, but there is definetly a point where you have less Amp consumption with 2 instead of 1 motor.
Itīs a matter of calculation since the wire losses (which can make 90% of the losses depending on current drawn) in the motor increase squared with the Amps, while other losses stay constant (at constant voltage).
If 1 motor is running somewhere way above itīs efficiency maximum and the second motor is attached the wire losses are only 50% (1/4th x 2) of the losses of 1 motor.
So lets say 1 motor is running @ 20A with an efficiency of 60% it produces an output power of 144W.
If we attach the second motor the power consumption of the boat stays the same @ 144W.
If the efficiency of the motors at 8A is then 75% the motors will only draw 192W or 16A out of the battery, which is again 144W output power.
If we now calculate the added weight of the motor with an additional 20W power consumption and 73% efficiency (higher amps --> less efficiency) on the 2 motors theyīll take 224W or 18,6A. Still makes sense and produces a lot less heat out of the electric energy in the battery.
That is by the way the basic principle in all electronics to reduce losses. Itīs often better to use 2 (weaker) MOSFET instead of 1.
For sure if 1 motor is running in the area of itīs best efficiency itīs absolute "xxxxx" to add another one
