The skeg is glued into place and I am working on my rudders now. I have the blades just about done and the parts that glue into the hull and are roughed out, the tube inserted, and glued and the epoxy is curing as we speak. I will sand them to profile, and then cut the holes in the hull for them.
Once the rudders are in, I will start some of the clean up work on the bottom and get that bit all ready for a good coat of primer.
You can see that I extended the centering marks beyond where the larger holes will be. That way, when I expand the holes, I will still have reference points. Don't ask how I know this.
Tom
