Author Topic: Gas tank pressure gauge  (Read 6591 times)
coolbumble
« on: August 04, 2015, 08:36:23 pm »
Advice please.
I want to fit a pressure gauge to my gas tank I use butane or butane / propane (70-30) from disposable cans but never sure if the tank is full! Hence a pressure gauge to assist me! What max pressure gauge would I need?. I propose fitting another on /of valve after the gauge.
All advice welcome
My regards
Ian  :-))
rhavrane
  • Steam passionate collector
Re: Gas tank pressure gauge
« Reply #1 on: August 04, 2015, 09:49:15 pm »
Bonjour Ian,
Personnally, depending on what I can buy/find, I use 1 - 6 or 1 - 10 bars steam pressure gauges to control my gas tanks.
During the refill, the pressure goes up to 2 - 3 bars but quickly, the pressure falls to less than 1 bar.
The bigger the torch is, even if the tank is large, the colder the tank becomes and the pressure falls close to 0 bar, this is why some of my friends install what we call the "liquid phase" to keep a constant pressure (with an additional gas regulator).
Examples :
https://www.youtube.com/watch?v=o2aWzYf-g9I
https://www.youtube.com/watch?v=_fTK6RuQXn4
https://www.youtube.com/watch?v=utYZJDJPBVg
https://www.youtube.com/watch?v=m5zmisFCIT8 (now the tank is heated, I can keep a pressure of about 1 bar)
For this steam plant https://www.youtube.com/watch?v=VxBGnpX77tA the tank was too close to the boiler and the gas pressure was always 10+  bars ==> I have moved it away in front of the torch https://www.youtube.com/watch?v=KPt0ouL8kzc
Raphaël
mrsgoggins
« Reply #2 on: August 04, 2015, 10:53:07 pm »
A pressure gauge will not , I'm afraid, tell you how much gas is left, only weight will do that. Weigh the tank before and after each run and note the duration and you will soon gain knowledge of your gas consumption.
coolbumble
« Reply #3 on: August 05, 2015, 09:11:58 am »
Many thanks Rhavrane.
I've watched the video's and taken note of what you have said.
I must complement you on your lovely models,
My regards
coolbumble
« Reply #4 on: August 05, 2015, 09:18:25 am »
Hi Mrsgoggins
Many thanks for your reply.
That's interesting as I was not sure if a gauge would help me. Thanks for the info.
My Regards
AlexC
« Reply #5 on: August 05, 2015, 01:08:51 pm »
Hi Ian,
A pressure gauge will only display the vapour pressure  at the time it is read...which will change with temperature.
As mrsgoggins has stated above... you need to weigh the tank before and after filling to establish the amount of liquid gas there is.
If it is any help...
70/30 Butane/Propane (liquid state) weighs 0.4628 gm per cc (ml)
or 13.15gm per flu. oz (UK).
Pure Butane (liquid state) weighs 0.479gm per cc (ml)
or 13.6gm per flu.oz (UK).
Your gas tank will (should) not be full to the top with liquid gas... the level is usually limited (by the filler valve venting system)to between 2/3rd and 3/4 full... you must have a space above the liquid for vapour to form.
Best regards.
Sandy. :-))
Jerry C
« Reply #6 on: August 05, 2015, 01:25:15 pm »
A sight glass would be of more (dubious) use than a pressure gauge which is useless.
Jerry.
AlexC
« Reply #7 on: August 05, 2015, 01:31:20 pm »
Jerry.
It would indeed, however it would have to withstand the 375psi pressure test. %) <:(
Sandy. :}
Jerry C
« Reply #8 on: August 05, 2015, 02:08:54 pm »
Hi Sandy, my Maccsteam gas tank certificate shows an hydraulic test pressure of 300psi. At what temperature does propane/ butane mix vapour pressure become problematic? At what pressure do Ronson type filling valves vent? I'm pretty sure I've seen small gas tanks fitted with 5mm sight glasses.
       It's always puzzled me why liquid gas vents from the filling valve when tank is full as there must be gas at the top of the tank.
Jerry.
rhavrane
« Reply #9 on: August 05, 2015, 06:29:07 pm »
Bonjour,
You can admire there a lot of beautiful boats, but please have a special glance at 7'10"  ;)
https://www.youtube.com/watch?v=n7xt4v4QK70
Besides this, I know all the time capacities of my gas tanks, the gauge let me know if I really have no more gas or if I have unintentionally used my RC safety gas valve.
Raphaël
AlexC
« Reply #10 on: August 05, 2015, 11:54:38 pm »
Jerry.
Hi Jerry,
The test pressures for LPG tanks are calculated from the maximum possible vapour pressure achievable under conceivable storage conditions at a specific temperature.
In the UK this is specified as 35deg C (shade temperature).
A safety factor of x 1.9 is applied which results in the following test pressures: -
Butane (100%)                 = 14.5bar (211psi)
60/40 Butane/Propane       = 26bar (375psi)
70/30 Butane/Propane       = 23bar (330psi)
All UK manufacturers are required by law to apply the appropriate test pressure for the specific gasses their refillable tanks are designed for.
I believe the rest of Europe also apply these same test pressures in order to be compliant for export/import between member countries.
Other countries of the world will vary depending on climate and regional legislation.
With a test pressure of 300psi your gas tank is more than capable for Pure Butane but falls a little short for 70/30 Butane/Propane mix if full compliance is required where you use it.
Gas vapour can become problematical at any temperature when mixed with air and the vapour content in air lies between approx. 1.9% and 8.6% for Butane (100%) or 2.4% and 9.6% for Propane (100%)... these are the combustion limit range values... all other mixes of these 2 gasses remain with these levels.
Self ignition temperature, in air, is approx 900deg F (482deg C).
When filling a tank via a Ronson type valve the liquid flowing into the tank displaces a small amount of vapour which actually flows out of the valve.
When the level of liquid in the tank reaches the bottom of the valve it spurts out of the valve, indicating that the tank is full.
In a correctly manufactured tank the valve is recessed into the tank body such that the bottom of the valve is at between 2/3rds and 3/4 of the tank capacity... thus ensuring there is sufficient vapour space above the liquid.
It is a very clever device really, albeit quite delicate and easily damaged with rough use.
I am not aware of any manufactured small gas tanks fitted with a gauge glass... the ones shown in Rhavranes video clip are the first I have ever seen but I am not sure if they are a standard manufactured item... they look more like custom built units to me, but I could be wrong.
I hope this answers your questions.
Stay safe.
Best regards.
Sandy. :-)) :}
rhavrane
« Reply #11 on: August 06, 2015, 07:57:13 am »
Bonjour,
I confirm, the tank equipped with a glass has been built by a French steam passionate who has a great mastery of the mechanics and his tools.
I have also seen one another similar tank, with the glass on one side, but impossible to remember in which video of presentation.
This means it is possible to do it but it is very complex, so it does not worth it for a manufacturer either in terms of money or risks.
Raphaël
Jerry C
« Reply #12 on: August 06, 2015, 07:59:09 am »
Sandy, thanks for that, it all makes sense. I looked at some vapour pressure graphs, I'm not sure what the pressure scale is, looks logarithmic or maybe exponential, anyway difficult to read pressure above 30C. I can see that the window type glass shown is subject to very high forces compared to a small bore glass tube type.
Mike at Macsteams certificate does specify not to exceed 70/30 Butane/propane mix. Anyway so far so good.
Thanks again.
Jerry.
rhavrane
« Reply #13 on: August 07, 2015, 05:45:58 pm »
Bonjour,
Another tank with a glass made by my friend Jean-Claude (seen at 55") as he builds everything except manometers :
https://www.youtube.com/watch?v=pMRjeZbE1SI
Raphaël
KBIO
« Reply #14 on: August 07, 2015, 08:59:16 pm »
Hello! :-)
Personnally, I favour the sight glass on my gas tanks whenever the tank has a big volume.
Just to know where the level is, above all when I have'nt sail for a while. My first boilers had no sight glass and I got along with it.
This kind of item is hanot neccessary but it brings some confort and some challenge in manufacturing.
Below, two type of sight glass.
 Also, I use quick removal guage on my installations during the test period. I know what pressure i start with and I know how fast the pressure drops. Thus I can adapt my burner jet.
All those are useful gadgets.
KBIO
« Reply #15 on: August 07, 2015, 09:17:31 pm »
 :embarrassed: Sorry I pushed the wrong button before I finished.
I wanted to underline that we have sight glasses on our boilers which work up to 10 bar in my case. At this pressure, it is hot (+/- 170°C) and still, we never had no problem unless the glass is dammaged for another reason.
We prohibit the use of propane in France, for obvious reasons of controling the pressure in hot environment. Storage is not a problem ; see pressure test. Managing this pressure after is more difficult.
The graph below shows the Butane & Propane pressure according to temperature. We can see that leaving a gas tank in the sun, pressure with Butane is only 8 bars. Nothing to worry with.
With the Propane it is more scary as we reach 19 bars at 50°C.
Now, if we use the 70/30 mixture, and if we extrapolate on the given graph we can see that the difference in pressure is nothing.
I did some test by leaving a full gas tank in the sun, with 100% Butane and another one with 70/30 and the difference of pressure when stabalized, was ......................1/2 bar only.
The temp of flowing gas in our installations, even by cold weather will never go below 0°C as the butane as ebulition temp is : 0°C . In 70/30 mixture, only the Propane will escape first draining some Butane, but the presssure will drop fast as the butane will remain in the bottom when all the Propane is gone.
I don't know if I made myself clear enough, but I tried with my poor english! %% Thanks for reading me and for your comprehension.
Regards.
http://modelismenavalradioc.nouvellestar6.com/c9-modelisme-bateau-a-vapeur
coolbumble
« Reply #16 on: August 11, 2015, 11:27:46 pm »
Many thanks to  all for sharing your experience information and pictures. On the advice I have now made the Gas tank removable. I have weighed it empty and full so now wait to see what the duration is in the water.
I ran a "dry" test today  and got over 25 minutes that would seem more than enough.
While doing so I took a few picture's of its unconventional crew which I will post on a separate thread
Many thanks to you all
Ian  :-))
Page created in 0.594 seconds with 17 queries.
