Author Topic: Prop shaft sealing  (Read 1917 times)
mckenzig
Prop shaft sealing
« on: August 10, 2015, 07:30:44 am »
My first boat was a kit called Ulisus which turned out ok apart from taking on water threw the propshaft. I am now building a North Sea dragger and hope the same does not happen to it. Would be interested in any thoughts that readers have on the subject.
john44
Re: Prop shaft sealing
« Reply #1 on: August 10, 2015, 08:24:18 am »
Hi Mckenzie, firstly did you grease the shaft during assembly? Is there an oiler tube fitted to the
Prop outer tube? The grease or oil act as a seal in the tube to stop the ingress of water.
Especially when in reverse where water can be forced up the tube by the propeller.
