Pages: 1 2 [3]   Go Down
Author Topic: HFM 590 yacht  (Read 12200 times)
U-33
  • K-157 Vepr. Akula-11
Re: HFM 590 yacht
« Reply #50 on: August 15, 2015, 04:07:28 pm »
Good point...no, there isn't. The only way to do that is undo the grub screw, drop the rudder out and grease, then reassemble. I'll come up with something....
rickles23
    • Royal Navy Commandos
Re: HFM 590 yacht
« Reply #51 on: August 15, 2015, 04:12:11 pm »
Best to sort it out now as it would be very tricky when the yacht is built.
Been there...done that!
U-33
Re: HFM 590 yacht
« Reply #52 on: August 15, 2015, 04:16:10 pm »
Good thinking, Mr Rickles sir...the rudder support is hollow, so the easy way would be to drill into it, add a short length of brass tube with a length of (capped) silicone tube attached to it, and drip warmed grease through the tube.
Martin [Admin]
Re: HFM 590 yacht
« Reply #53 on: August 15, 2015, 05:30:07 pm »
What sail servo?
U-33
Re: HFM 590 yacht
« Reply #54 on: August 15, 2015, 05:31:10 pm »
Futaba S003 servo with the kit sail arm attached, Martin, same as the rudder one.
Re: HFM 590 yacht
« Reply #55 on: August 15, 2015, 06:17:00 pm »
How long is your piece of string Rich?
If you think the cord supplied is ok  then use it,
If it is synthetic and has not been subject to
UV light it should be ok.
If not, the offer of dyneema is still there.
Just measure what was supplied and I will send
it plus a bit extra.
PM me your address and length {-) and I'll drop
it in the mail.
U-33
Re: HFM 590 yacht
« Reply #56 on: August 16, 2015, 11:29:58 am »
I haven't got round to measuring the thread lengths yet, Ned...haven't even unpacked the rigging thread yet.
Been cutting out hatches and making some clear covers out of old cd cases.
Re: HFM 590 yacht
« Reply #57 on: August 16, 2015, 11:43:12 pm »
Rich I have never heard of a Yacht that has a greasing point on the rudder...mine was last greased up 4 yrs ago and it still doesn't leak,so top tip don't create a rod for your back or even if it ain't broke don't try and fix it and reinvent the wheel
U-33
Re: HFM 590 yacht
« Reply #58 on: August 17, 2015, 09:31:48 am »
Good point Dave...thanks.
Martin [Admin]
Re: HFM 590 yacht
« Reply #59 on: August 17, 2015, 09:40:48 am »
Worse case, you can pull the whole rudder out, re-grease and reassemble - you can get to both ends.
U-33
Re: HFM 590 yacht
« Reply #60 on: August 17, 2015, 09:42:29 am »
True, Martin...it only takes a minute to undo a couple of grub screws, drop the rudder out, grease and reassemble.
Pages: 1 2 [3]   Go Up
