A major cock up has occured with the outer skinning of the hull. In places the resin matting has refused to bond to the hull properly or refused to set. This may cause problems with the final finish later down the line so after trying to solve the problem for several days I have decided to switch to Plan B!!
This means that the grp hull I have is in for a major remodelling job, sort of a face lift and nose job combined with botox!!!
Inside the hull the keel space at the bow and strern has been filled with resin to allow the outside to be reshaped with the big power sanders.
The profile of the sheer line has also been altered as new decking sections have been added.
The stern has also been 'remodelled with the sanders and the positions for the exhausts and ram boxes plotted.
The shafts and rudder blocks are now bonded in place in this hull.
New motor mount is under construction.
I have also solved the problem of making the recesses for the exhausts that are moulded into the stern During a visit to a local pound shop this morning the answer appered in the shape of plastic shot glasses!! The base of these are the correct diameter for the recesses. So a section was cut off the lower end of the glass.
Styrene discs were cut and glued to the removed section. These are where the bolts that hold the pipe in place are fitted.
34mm diameter holes were cut into the stern with a stepped cone drill.
The new recesses bonded and sealed in place, after sanding flush the exhausts themselves can be added.
Next on the agenda will be the reinforcing for the end of the tunnels and the ram boxes.
Can now relax at the Blackpool Boat Show tomorrow, talk Lifeboats with old friends and pick up more supplies for the build.
