Author Topic: Vosper MTB 379  (Read 3758 times)
drover
Vosper MTB 379
« on: August 22, 2015, 08:01:33 am »
I have just obtained Barrie Griffin's plans for the Vosper MTB from Traplet.
The plans specify 1/4" balsa for the keel and formers. I have 1/8" liteply to hand that I bought for a model that I have had to postpone building, would it be detrimental to the build if I used this instead of balsa?
Also I just discovered there is a DVD available covering the build, any one recommend this? As I am still a novice with powered models and it is only about a tenner I suspect getting it could do no harm.
Re: Vosper MTB 379
« Reply #1 on: August 23, 2015, 01:44:58 am »
A 1/4" is a !/4" light ply is partly balsa anyway. The plan material is surely only a recommendation. Balsa is light and easily cut and is therefore a popular medium. Except in aircraft and warship superstructures weight is not usually a concern. Go for it.
Doug
BrianB6
Re: Vosper MTB 379
« Reply #2 on: August 23, 2015, 08:27:16 am »
I built my model many, many years ago, and used 3 mm. ply bulkheads, 1/4 x 1/4 spruce stringers and 1/16" ply skin sides and 1/32" ply underneath.
I still have the hull although it has been chopped and changed several times.
Propulsion was by several diesel engines from 2.5 cc. to 5 cc. and she performed beautifully.
Page created in 0.015 seconds with 21 queries.
