Author Topic: Working towing winch  (Read 3284 times)
Fastfaz
« on: August 31, 2015, 05:03:22 pm »
Yo all,
    Can anyone help/advise me how to make a towing winch that works with suggestions for the layout where everything goes etc? I remember seeing a post from Norry (Glasgow) about how to do it but can I find the post "platting chance fog of more". The winch needed a motor from a cordless screwdriver which I have acquired but after that my brain, if I have one that is, has come to a stop. Help needed.
      Cheers all, back to the cider.
             Faz. <:(
Re: Working towing winch
« Reply #1 on: August 31, 2015, 08:01:10 pm »
Could you use the switch from the screwdriver still wired in and then use a servo to operate it? You can get high torque servos. You might be able to remove the spring from the switch to make it easier to operate remotely.
If not can you use a high ampage ESC and an auxiliary channel with a three way option so you have neutral?
knoby
« Reply #2 on: August 31, 2015, 08:17:26 pm »
The path of excess leads to the tower of knowledge
« Reply #3 on: September 01, 2015, 11:32:22 am »
Might be best also putting the subject topic name and what page it was on as this link just goes to the front page - oops - sorry was in guest mode - it works  :embarrassed:
