Author Topic: Which speed controllers do need  (Read 4457 times)
timbo
« on: September 03, 2015, 12:28:51 pm »
Hi
Novice needs help
Just ordered the motors for my lifeboat build, I have gone for a couple of Turnigy 3542/6 1000Kv the
headache now is which speed controllers should I use these is so many out there its  {:-{ mind boggling, can anybody guide me in the right direction, another thing is what does it mean when it has BEC SBEC or UBEC mentioned in the information.
Tim
inertia
Re: Which speed controllers do need
« Reply #1 on: September 03, 2015, 01:19:04 pm »
These are popular http://hobbyking.com/hobbyking/store/__28224__HobbyKing_120A_Boat_ESC_4A_UBEC.html
You need one for each motor, and don't forget to buy the programming card - it makes setting them up much easier than via the Tx.
Anything which has BEC (Battery Eliminator Circuitry) at the end means that the main motor battery also powers the receiver via the normal 3-wire (servo) plug connection to the speed controller. For practical purposes SBEC and UBEC are higher-current versions of the same process. If you have two speed controllers which both have BEC then you need to disable the BEC in one of them. See here and scroll down to "Disabling BEC ESCs". http://www.action-electronics.co.uk/wd.php There's also an explanation of BEC under 'Articles' on the same website.
DM
timbo
« Reply #2 on: September 03, 2015, 03:04:14 pm »
Thank
Much appreciated  :-)) :-))
canabus
« Reply #3 on: September 19, 2015, 11:25:51 am »
Hi
I use the Hobbyking car ESC's 60A(no water required) electric fan, smaller.
Power on/off switch on the ESC(no big main power switch required).
Programming card required.
You would only require a 45A ESC, but, your motors will run 14.8 volts(4S) so why the 60A ones.
Weight different 22 grams.
« Reply #4 on: September 19, 2015, 12:09:50 pm »
This one?
http://hobbyking.com/hobbyking/store/__11743__HobbyKing_8482_Brushless_Car_ESC_2S_4S_60A_w_Reverse.html
I've bought the 30Amp (without fan), how do they fare if it get slashed splashed?
http://hobbyking.com/hobbyking/store/__31779__HobbyKing_Brushless_Car_ESC_30A_w_Reverse_UK_Warehouse_.html
Hi
inertia
« Reply #5 on: September 19, 2015, 01:13:45 pm »
how do they fare if it get slashed?
Not quite with you there, old thing. Would you care to evaporate elucidate?
DM
richald
  • Retired and loving it!
« Reply #6 on: September 19, 2015, 03:31:18 pm »
DM
your use of the word evaporate may have been more relevant! - I guess Martin is talking about the ESC getting splashed !?
Richard
Senior member of the OGG (Order of the Grumpy Gits)
Membership Number : 002
inertia
« Reply #7 on: September 19, 2015, 05:43:16 pm »
Ah! Thanks for that, Rich. Round here "slashed" has several different meanings.  :o
DM
« Reply #8 on: September 19, 2015, 05:56:53 pm »
 :embarrassed:... yes, "sPlashed", ahem!    :embarrassed:
 As they are "car" ESC's are they susceptible to water ingress?
« Reply #9 on: September 19, 2015, 07:38:05 pm »
This one?
I wouldn't use those in damp conditions, several members at our local rc car club use them and they are sensitive to wet/damp conditions
