Author Topic: What a feat of engineering  (Read 5847 times)
Brian60
« on: September 11, 2015, 07:18:30 pm »
This would make a magnificent model. I reckon ballasting might be difficult with all that hanging off the starboard side though.
https://www.youtube.com/watch?v=54Do3n0CM1A
Re: What a feat of engineering
« Reply #1 on: September 11, 2015, 07:42:06 pm »
about a minute in of the video, did you notice how much there appears to a significant wobble at the top of the apparatus off the right hand side, some weird effect
« Reply #2 on: September 11, 2015, 08:07:24 pm »
Well you've got my attention Brian.    {-)
What a beast.  A bit over the top methinks.
ken
Brian60
« Reply #3 on: September 11, 2015, 09:32:33 pm »
Be a gud un to have next to your seabex Ken.
Brian60
« Reply #4 on: September 11, 2015, 09:35:14 pm »
It happens about 30 seconds in as well mate. I reckon its down to the video compression to make the file smaller for youtube. Somebody has just done a poor job of it.
« Reply #5 on: September 11, 2015, 10:19:21 pm »
I wonder if crane No 7 can swivel from midships anticlockwise x 300 degrees or just have a very high luff? .....Derek
Seacommander
« Reply #6 on: September 12, 2015, 12:02:55 am »
Looks magnificent and would make a great model for shore........
Wouldn't like to be on that,  in the middle of the Atlantic in a force 10.........
Mark
« Reply #7 on: September 12, 2015, 09:56:45 am »
Well I do have another  Seabex hull, this time the original from the makers, sitting around waiting to twinned up maybe  !!!
ken
nemesis
« Reply #8 on: September 13, 2015, 05:56:15 pm »
What ever is on top has to be balanced by what is underneath, I would love to know what is under to balance that lot on top. Does anybody know the capacity of the crane? Nemesis
nivapilot
  • re-invented rc boater
« Reply #9 on: September 13, 2015, 06:09:31 pm »
Brian60
« Reply #10 on: September 13, 2015, 08:56:15 pm »
5000t.?....according to this....http://www.subsea7.com/content/dam/subsea7/documents/whatwedo/fleet/rigidpipelay/Seven_Borealis.pdf.... :o
That is quite some statistics om that PDF. 127 cabins and berthing for 399 crew :o
oldflyer2
« Reply #11 on: September 14, 2015, 11:02:14 am »
That is an incredible vessel!
Tom
TailUK
« Reply #12 on: September 15, 2015, 01:20:42 pm »
I think that's an effect of the digital video.
Mad Scientist
« Reply #13 on: September 15, 2015, 10:00:06 pm »
Ooh! Cabins! A level of luxury I can only imagine.
They might have saved some space by doing things the Navy way - stuff them into seven 54-man messdecks.  378 berths, with the remainder (the senior ones, obviously) in 4-man cabins.  <*< After all, it isn't a pleasure cruise. ok2 - Tom
Mad Scientist
« Reply #14 on: September 19, 2015, 09:08:30 pm »
Here are photos which might help to answer your questions about what's under water to balance the crane on one of these ships...
If the photos don't show, here's the link to the article: http://gcaptain.com/ship-photos-crane-ship-wei-li-in-damen-drydock-for-maintenance-and-repair/#.Vf2-xpe8p_d
Tom
« Reply #15 on: September 19, 2015, 10:40:37 pm »
Hullo Tom...I think the answer to your question...'what's under water to balance the crane on one of these ships?'.....is nothing  >>:-(
The image of the vessel in dock show the substantial number of additional supports under the stern supporting the weight of the crane, [in addition to the standard dock block formwork], so water must be supporting that same mass when at sea & therefore the hull structure in turn must also be the consideration
The WEB site link didn't really explain the pair of horizontal structural tubular fenders at the bow at the waterline, however above them on both sides are what appear to be pairs of wire feed spooler sheaves. Again, the WEB site does not mention or explain any specific or unique engineering on board facilities.... Derek
Brian60
« Reply #16 on: September 20, 2015, 07:55:37 am »
Derek the structures on the bow are for docking a Stevpris / Danforth type anchor- much larger than the normal Hall ship mooring anchor. One would be deployed at each 'corner' of the ship to hold her in position while the crane was working. Nowadays its done with bow and stern thrusters and dynamic positioning via gps satellite. I remember working on a model of the Stena Seawell back in the mid 80's that had the same set up. The ship would be moored on station and the four winches would work together to keep the ship on station.
The way it works is, imagine a X your mooring position is in the centre. You manouvre to top right, drop the stb bow anchor, pay out the cable and manouvre sternwards to lower right, drop the stb stern anchor, pay out cable. Do the same for the other two legs and then manouvre back to centre, paying out or taking up cable on the winches as necessary. Once over your 'spot' all the winches tension the cables to hold you there.
As you will by now have realised, the time taken to achieve this could be the best part of a day. Arrive on station and hold yourself there with thrusters and dynamic positioning is so much faster- time is money!
« Reply #17 on: September 20, 2015, 08:14:26 am »
Would this be more stable than 'hold yourself there with thrusters and dynamic positioning', for crane use?
Brian60
« Reply #18 on: September 20, 2015, 10:56:46 am »
I suppose it all depends on what you are lifting. If you are drilling even semi submersible rigs still use cable and anchors to hold exact position, so cable/anchors still have a role to play over azimuthing thrusters and dynamic positioning systems.
« Reply #19 on: September 20, 2015, 01:37:08 pm »
keeping on station by thrusters alone is ok for short term work like lifting a module on an oil rig, but if you drilling as this appears to be, then the fuel cost would be too great and a steady delivery difficult so paying out anchors is a more cost effective option for the time 'on station'.
