Author Topic: Steam powered Sealight, or how to fit a quart into a pint pot....  (Read 7151 times)
pettyofficernick
« on: September 18, 2015, 06:33:58 pm »
I have not done much boat building of late, the last being the African queen. I have been dabbling in the black art of model engineering. So, after refurbishing Victoria with a new engine and a coat of paint to get her  ready to sell I have made a start on the Mountfleet Sealight  1/32 Puffer kit I got at Haydoch 2013. I have seen a few puffers running on steam, but the boiler is invariably in the cargo hold, and being one for a challenge, decided I was going to put the boiler in the boiler room and the engine in the engine room, well, near as damn it anyway. I have a little 3 inch x 6 inch vertical boiler, which is a slightly modified Tubal Cain Henry design, and for the engine, the old Victoria engine, now rebuilt with new pistons, con rods and big ends. It was clapped out after 4 years of constant use but now is as good as new. It was all going to be a tight squeeze but so far, so good, just need to find room for a seperator tank. I will use a stove type gas canister and a can valve for fuel, this can sit in the hold. I have made the quarter deck removable so if in the future anything major needs doing, I can lift the whole assembly off. For the purposes of this excercise, I put the deck on first and worked through the hole, if I can get it all in that way, I should be ok. a couple of 22mm offset end feed plumbing fittings was all that was needed to re route the funnel, and the only compromise I have made is to move the funnel 1/4" forward, and lift the superstructure by 1/4", none of which should be noticeable unless some smart Alec takes a ruler to it. I will stop waffling now and put in some photos of progress so far, I only really started yesterday so not done too bad so far....
Jerry C
Re: Steam powered Sealight, or how to fit a quart into a pint pot....
« Reply #1 on: September 18, 2015, 06:57:09 pm »
Looking forward to this build PO.
Jerry.
pettyofficernick
« Reply #2 on: October 06, 2015, 09:11:46 am »
Got the position of engine and boiler finalised now so today I can start making it permanent. The next, and probably trickiest part, is shoehorning all the other bits in, seperator tank, lubricator, servos etc....
pettyofficernick
« Reply #3 on: October 09, 2015, 06:02:27 pm »
Next job knock up a lubricator. It was quite obvious that if it was attached directly to the engine I would not be able to reach it for emptying/filling, so it is positioned next to the stop valve, when the superstructure is off, it is easily accessible.
The copper tube is for an oil seperator tank, this I intend to fix to the inside of the hull under the deck, with a screwed lid coming up through the deck, disguised as a bucket or similar. It will be about where it is now, but inside. I have also made a little hood to sit on top of the safety valve, it will, in due course, be piped to the safety valve pipe on the front of the funnel.....
pettyofficernick
« Reply #4 on: October 12, 2015, 06:29:38 pm »
Servos now fitted, just got to do the seperator and hopefully, weather permitting, trials Wednesday.I think I may need to have a slight rethink re the safety valve pipe, it seems to be stopping the casing from sitting snugly...
 for my next project......
pettyofficernick
« Reply #5 on: October 14, 2015, 05:21:51 pm »
First trials today....
https://youtu.be/6ctx97drOXk
dave301bounty
« Reply #6 on: October 14, 2015, 06:38:24 pm »
Nick ,I like your effort ,you have got a good determination ,well done . :-))
« Reply #7 on: October 14, 2015, 06:47:43 pm »
Looks really good Nick.
Wish our pond had been as smooth as that today.
We had a North Easterly 20 Knots and darn chilly >>:-(
pettyofficernick
« Reply #8 on: October 14, 2015, 07:34:38 pm »
Thanks Ned, you sheltered our side of the country from the nasty ol wind...
SailorGreg
« Reply #9 on: October 15, 2015, 08:57:26 am »
Nicely done Nick.  That really is a quart in a pint pot, and very neat too.  I'm looking forward to seeing the finished puffer puffing merrily.  :-))
Greg
muleears
« Reply #10 on: February 02, 2016, 02:44:34 am »
Beautiful work Nick!  I look forward to the finished version.
Cal
Washington, NC USA
Proud owner of:
75% complete Krick Victoria
75% complete Billing African Queen
Krick Alexandra
Lots of building, very little steaming!
pettyofficernick
« Reply #11 on: February 02, 2016, 10:24:36 am »
Thanks Cal, progress slowed down due to arthritic hands, hopefully will get going again once weather warms up a bit and hands feel better.....
KNO3
« Reply #12 on: April 09, 2016, 01:25:55 pm »
Nice to see a the steam plant installed in a puffer where it belongs and not in the cargo hold. I'll follow your thread with interest.
Page created in 1.697 seconds with 17 queries.
