Author Topic: F1 Mirrors  (Read 2581 times)
Jerry Hill
F1 Mirrors
« on: September 23, 2015, 12:26:41 am »
One simple scale feature that just tips off the realism of a semi scale F1 to me is the mirrors. I thought I'd show how I've settled on how to make them. The following images are from a couple of models
First a wooden former is made up to a good standard, the better the former is the less work needed further down. I used Rock Maple which can be polished without waxes through fine rubbing down alone. A plywood board with a matching hole plus material thickness is used to simply push heated Polycarbonate sheet over the former to make the shell, there's no need for a vacuum at this scale.
Suitable bolts are heated and bent to act as the stalks, upsetting the head helps to provide an anchor for bonding into the shells.
The mirrors themselves are made from Mitsubishi Mirror, a chrome plated aluminium/polypropylene sandwich. The reflecting surface is on the outside so there's no looking through glass, and it's safe and easy to cut and shape.
The bolts are bonded in using flat steels and a clamp to keep things in line:
Here I've used JB Weld:
I then paint the shells using multiple coats of 2K Acrylic with just a flash off in between, this blends the stalks into the shells and rounds out the edges. It's also tough paint.
The mirrors are then settled on to a bonding filler, I use KwikFill. Here you can also see some threaded collars added. These act as a stop:
Ferrules, roughed up for bonding into the canopy:
For which I use either Epoxy or JB Weld:
To the threaded end of the stalk I fit a lever on to which an elastic band is fitted. In essence then the mirrors are spring loaded. I figured this had to be done as they are just too vulnerable otherwise:
So there you go:
And an earlier rectangular version:
Re: F1 Mirrors
« Reply #1 on: September 23, 2015, 01:08:13 am »
Spring-loaded door mirrors - I LIKE IT !
Well done Jerry. REALLY effective.  :-))
BenVK
Re: F1 Mirrors
« Reply #2 on: December 04, 2015, 01:27:09 pm »
They look great!  :-))
Can I ask where you got the ferrules from or were they scratch made?
Jerry Hill
Re: F1 Mirrors
« Reply #3 on: December 04, 2015, 01:35:54 pm »
Thanks.
Yes, ferrules made from scratch.
BenVK
Re: F1 Mirrors
« Reply #4 on: December 04, 2015, 01:42:17 pm »
Thought so, thanks.
When you say Mitsubishi Mirrors, what exactly do you mean, interior car mirrors?
I'd like to make some mirrors myself but for my RC P51 and Spitfire.
Jerry Hill
Re: F1 Mirrors
« Reply #5 on: December 04, 2015, 02:06:01 pm »
It's a decorative mirror laminate made by Mitsubishi, a Google search will find it I'm sure.
xrad
  • Keeper of the Sun Dried Tomato
Re: F1 Mirrors
« Reply #6 on: December 07, 2015, 01:21:05 pm »
Excellent work there, Jerry!
Page created in 0.091 seconds with 22 queries.
