Author Topic: NEWBIE's first build  (Read 3185 times)
TheOldMan
« on: September 29, 2015, 11:39:56 am »
Although I have made static models before (cars & trucks ) this is my first time with a boat, and I have never done anything with R/C and don't know anything about it.
So after reading a lot on here and other places I decided to have ago. I read about the Italeri Vosper, so got the kit sent out, very few model shops in Cyprus. Now as well as R/C I wanted a nice looking model and with a few mods original as possible. So to start with the rudder, most I saw had the rudder in the bottom of the hull, but I want original. So I went to S.H.G and they supplied the motors,kit type rudders etc. Having looked at the rudders I came up with the idear of modifying to what I wanted. I used the tube, and cut an arm to shape,and it was a very tight push fit over the wire and epoxy it on.  Will Update this.
TheOldMan
Re: NEWBIE's first build
« Reply #1 on: September 29, 2015, 12:18:38 pm »
Right just resized a few more pics for you, no need for any explanations pics should say it all, but I will be pleased for constructed views. Thank you Stan for the aerial idear.
Martin [Admin]
« Reply #2 on: September 29, 2015, 12:52:01 pm »
You're gonna have issues with your rudder servo, either the arm binding against the hull side or
asymmetric rudder movement!
You may also have leaks via the arm through the transom!  {:-{
TheOldMan
« Reply #3 on: September 29, 2015, 01:16:15 pm »
I have tested the hull out slow and fast and no water goes in. the prop wash is well away from the stern I used my test pool, as for the servo it is touching the hull side when over to port so I only use the stick to the point of it touching. I will have to do a mod on it, any idears welcome. As I said this is new to me. Thank you.
TheOldMan
« Reply #4 on: September 29, 2015, 01:22:04 pm »
Last lot of pics for you. As you can see I done a mod on the torpedo tubes so I could get to the screws, the front of the tubes is a tight fit so it wont come off. Hope its OK.
Perkasaman2
« Reply #5 on: September 29, 2015, 02:28:34 pm »
Well done, you are making an excellent job of the detailing. Excellent pictures.
GrahamD
« Reply #6 on: September 29, 2015, 02:45:16 pm »
Nice job.
Say hello to Nic and his wife the next time your in Nics Models in Limassol. I've known Nic for most of my life, and always visit when back in Cyprus.
Dan.Lord
« Reply #7 on: September 29, 2015, 03:31:26 pm »
Looking really nice  :-))  what scale is she ? Would be nice to see some piccys of her afloat in your impressive testing tank  {-)  Keep up the good work Dan.
TheOldMan
« Reply #8 on: September 29, 2015, 04:06:29 pm »
Thank you Graham and Dan for your comments. She is 1/35 SCALE. I am waiting for a new battery and other parts then I will get some pics of her in the test pool. We don't get to Limassol as we are the other side of Paphos, St George's near Coral bay. We don't have ponds here only reservoirs and they are to windy and rough, so I shall be using the harbour .
tonyH
« Reply #9 on: September 29, 2015, 05:53:08 pm »
Just a suggestion regarding the rudder throw. If you reverse the servo so the lever is at the aft end, you could shorten the arm and get the line of the throw in a better place?
Lovely model anyway :-))
Just an idea :-)
Tony
TheOldMan
« Reply #10 on: September 30, 2015, 05:21:19 am »
Thank you Tony.  The placement of the servo was governed by the leads, I am waiting for extentions to arrive then I can try all idears out, so will give yours a try. Chris
Tug Hercules Fireman
« Reply #11 on: September 30, 2015, 05:31:15 am »
An excellent build.
Where did you get the Crew Figures?? they are excellent.
Thank You.
Tug Hercules
Fireman Rick
“Ideals are like the Stars; We never reach them, but like
Mariners of the Sea, we chart our course by them.”
TheOldMan
« Reply #12 on: September 30, 2015, 06:33:35 am »
Thank you, they are the Italeri Vosper crew, which we got from e-bay.
TheOldMan
« Reply #13 on: October 02, 2015, 07:28:08 am »
 TonyH I did  turn the servo round and it works, the reason I did it that way was the length of the wires, I have found out that you can get extentions so have ordered some. Thank you.
Chris
