Author Topic: Bevel gears  (Read 9619 times)
Brian60
Bevel gears
« on: October 03, 2015, 08:34:15 pm »
Planning for my next project I'm going to need some bevel gears. In total it's about 16 of them :o But they can't be any larger than 9mm diameter across the face, teeth number is not important (more the better for meshing)
Couple of other things, shaft size big as possible and must be made of brass. So has anyone a supplier they can suggest please
Re: Bevel gears
« Reply #1 on: October 03, 2015, 10:25:24 pm »
Brian.......an American steam locomotive called the SHAY, uses conventional 3 cylinder vertical steam engines, but the power is transmitted to the driven wheels via pairs of bevel gears ....I have seen examples of model engines with 2:1 ratio bevel gear sets with the wheel being approx. 10 mm diameter  :o
...here is a link to a model build with plenty of detail of the gear sets .............Derek
http://www.modelenginemaker.com/index.php/topic,3778.msg69261.html#msg69261
grasshopper
    • A1 Hobbies Ltd.
Re: Bevel gears
« Reply #2 on: October 04, 2015, 01:47:58 am »
Try looking up Davall Gears on google, they do loads of gear related things, had a catalogue once and it made interesting reading. Small orders and model size products were available.
Re: Bevel gears
« Reply #3 on: October 04, 2015, 02:05:10 am »
http://www.davall.co.uk/
book marked for future reference.... some good stuff on there
Klunk
Re: Bevel gears
« Reply #4 on: October 04, 2015, 06:51:39 am »
meccano gears any good?
full time penguin
grendel
Re: Bevel gears
« Reply #5 on: October 04, 2015, 09:17:38 am »
even the small meccano bevel gears are about 13mm minimum, and you would be looking at a small mortgage for that quantity - lego do small bevel gears that might suit.
heres the smallest meccano one http://meccanoman.co.uk/catalog/product_info.php?cPath=1_14_17&products_id=1159&osCsid=bcd6b38b89006cfe9fe8d1ef4416ed01
at just over £5 each
heres the lego ones at just about 3p each http://www.brickowl.com/catalog/lego-tan-bevel-gear-with-12-teeth-6589. you would probably need lego axles to suit.
I too have a copy of davalls gearbook as a reference.
you might also find some bevel gears in old inkjet printers, I regularly rescue old printers and strip them down for gears shafts and small bolts.
Grendel
BarryM
Re: Bevel gears
« Reply #6 on: October 04, 2015, 09:21:38 am »
Motionco.co.uk may be able to help.
Barry M
david48
Re: Bevel gears
« Reply #7 on: October 04, 2015, 09:31:08 am »
Have a look here ,if only this was in good old Blighty .
http://www.smallparts.com.au/technical/timing/.  Ahhh I see its pasted the bit I was reading ,it will get you in the right area as usual follow the links to the bit you want .
Is it really dear to get things from OZ .
David
grendel
Re: Bevel gears
« Reply #8 on: October 04, 2015, 10:31:49 am »
One of the books / catalogs I got from Davalls was the handbook of metric drive components  by SDP SI, which has a bit of everything - gearboxes, timing belts and pulleys for them, magnetic slip clutches - a bit of everything you will be likely to need.
Brian60
Re: Bevel gears
« Reply #9 on: October 04, 2015, 12:13:26 pm »
Thanks everyone, as mentioned meccano ones are way too large, at 18mm diamter. The motionco ones are just about right size but in Delrin, their brass ones are not small enough.
I'll take a look at the other links this evening when we are back from afternoon lunch with our daughter and son in law. Then the journey back to Spain to think about tomorrow, we leave early on Turesday morning.
BarryM
Re: Bevel gears
« Reply #10 on: October 04, 2015, 12:52:22 pm »
OK, nobody else has asked and so I will: just what is this project that needs so many bevel gears?
Remember we have ways of making you talk. Not excluding exposing you to Martin's shirt wardrobe. (Insert appropriate smileys here unless, like mine, the system won't cooperate.)
Barry M
Re: Bevel gears
« Reply #11 on: October 04, 2015, 04:10:06 pm »
With four bevels to a drive, I reckon Brian is building something that in real life would need very accurate drives for positioning, so perhaps an exploratory vessel or something the Oil companies use with four schottel drives?
Re: Bevel gears
« Reply #12 on: October 04, 2015, 09:25:24 pm »
Think you are on the money here Ian.......a few weeks back we saw a vessel with a combination of multiple Voith drives & used for constant GPS positioning....
From memory  {-)...it had markings for twin bow tunnel thrusters, however the Chinese build only showed one single athwart ship thruster,  in subsequent images we detected a Voith schottel type drive just aft of the tunnel thruster that could be lowered for use & raised when not needed
I wonder if a model gyro from a helicopter be used in this application?..................Derek
Brian60
Re: Bevel gears
« Reply #13 on: October 04, 2015, 09:43:43 pm »
OK to put you out of your lust for info. I need four of these, 2 forward, 2 aft. But having spent an hours searching for gears, they came to over a £100 I am now on a different track!
Basically I was going to fabricate the housing, have a through prop shaft with a bevel gear in the centre, then a down shaft with  a matching gear to mesh together. The top end of the shaft would have matching gears to go to the motor drive. The whole unit would be revolved around at the top by a crown gear and suitable waterproof seals.
grasshopper
    • A1 Hobbies Ltd.
Re: Bevel gears
« Reply #14 on: October 04, 2015, 10:38:38 pm »
Can you not mount the motor vertically and eliminate one set of gears?
Not sure of the size of things but have you googled gear sets from slot cars? They use bevel gears but I'm not sure of the sizes. There are slot cars up to 1/24th so might be big enough.
johno 52-11
  • Model lifeboats built to perform
    • lifeboat Models
Re: Bevel gears
« Reply #15 on: October 05, 2015, 01:27:58 pm »
Hi Brian
Not sure if this is of any help but I used some nylon gears from HPC gears in my working outboards http://www.lifeboatmodels.co.uk/atlantic.htm
I did try and make some brass ones they did work but slipped on the shaft after a time so I'm back to using the Nylon ones and they work well.
Brian60
Re: Bevel gears
« Reply #16 on: October 05, 2015, 04:01:45 pm »
Hi Brian
This why I didn't want to use nylon/delrin, I reckoned they would slip on stainless steel shaft. I thought using brass gears I could solder to brass brass shaft.
I checked out what I could and like above those that are bevel gears and small enough are nylon. The larger sizes use standard sprockets made of aluminium, the motor mounted transversely to allow its shaft to line up with the sprocket on the axle.
Re: Bevel gears
« Reply #17 on: October 05, 2015, 04:05:04 pm »
Once you get the gears on the right place why not drill through the shaft and collar and drift a pin through
Re: Bevel gears
« Reply #18 on: October 05, 2015, 07:52:55 pm »
Put the motors in the pods and surround them with fine weave fabric so that while they might get wet, the weave will keep the very worst of the silt and glop out of the workings. I am sure that a chap of your skills could make two part pods saving oodles on gears etc, probably simpler to make as well. Could you utilise technology that model submariners use to keep their motors dry?
Brian60
Re: Bevel gears
« Reply #19 on: October 05, 2015, 08:10:56 pm »
Ian that was my first thought. But there isn't as far as I know a small enough motor with the torque required to drive 55mm props pushing a 1metre displacement hull.
Re: Bevel gears
« Reply #20 on: October 05, 2015, 08:19:37 pm »
Even in the brushless market? Hm.
Brian60
Re: Bevel gears
« Reply #21 on: October 06, 2015, 09:25:12 pm »
Brushless I have no idea over Ian, I've never used them. I did ask advice on another site, but so far have not had luck. If there was a small enough brushless that somebody could suggest I'd certainly give them a go.
cos918
Re: Bevel gears
« Reply #22 on: October 06, 2015, 10:09:33 pm »
what is the outside diameter of the pod housing ?
john
Brian60
Re: Bevel gears
« Reply #23 on: October 07, 2015, 08:26:39 am »
Motors could be up to 20mm diameter or a little more, certainly no more than 23mm or the outer pods will look too big for the scale.
Time Bandit
Re: Bevel gears
« Reply #24 on: October 07, 2015, 11:31:14 am »
As far as I know you will nit find anything suitable in the RC sector.
All motors gave too much rpm/V.
You could check at Maxon and Faulhaber. They make very decent motors with 22mm diameter.
Maxon EC22 is what you are looking after. Maybe you are lucky at ebay.
regards
Tobias
Page created in 0.099 seconds with 22 queries.
