Author Topic: Prop tube oilers.  (Read 15609 times)
Captain Povey
Prop tube oilers.
« on: July 29, 2007, 09:03:05 pm »
Hi all you experienced model boat men out there. It has been suggested that on oiler should be fitted to the prop tube to ensure constant lubrication and reduce wear of these parts during operation. I assume this means removing the rudders and prop shafts, drilling a small hole on top of the tube, cleaning out all the swarf and fixing a flip lid oiler over it. I am not confident about silver soldering one in place with a gas lamp and doubt that my electric soldering iron would store enough heat so is it totally stupid to consider Aralditing one in place. Some suggestions would be appreciated. Thanks Graham.  :-\
chingdevil
Re: Prop tube oilers.
« Reply #1 on: July 29, 2007, 09:11:54 pm »
Hi Graham
I use a 75watt soldering iron to fix my oilers to the prop tube. I always find that using araldite at any setting time does not stick to metal, it looks OK but can easily be peeled off. I also think that if it had not sealed properly there is always the chance of some moisture ingress.
I make my oilers out of a short length of brass tube soldered to the propshaft, then fit some flexible tubing that can be sealed after you have  oiled/greased the tube. I usually use tube the same size as one of my syringes, so can pump in the oil/grease.
Brian
« Reply #2 on: July 29, 2007, 09:26:35 pm »
After soldering the tube to the prop shaft tube, then place your drill inside the new tube and drill a hole in the prop tube taking care not to go through the other side of the prop tube. Make sure you clean out all the swarf.
chingdevil
« Reply #3 on: July 29, 2007, 09:59:00 pm »
Hi Dicky
I did not put that in my first posting ::) ::)
I always make the hole first, just large enough for the oiler tube, just in case I drilled through doing it the other way :D :D
Brian
« Reply #4 on: July 29, 2007, 10:06:25 pm »
Sorry Brian I always drill the hole last so i dont fill the shaft tube with solder. Also doesn't matter to much where the oiler tube ends up.
There you go 2 ways of How To Do It. ;D
red
« Reply #5 on: July 29, 2007, 10:11:04 pm »
If you drill the hole first and use a barbecue stick poked in the hole and slide the tube over, it holds the tube as you solder and does not take heat away from the soldering iron that pliers would take holding the tube.
fredy
Captain Povey
« Reply #6 on: July 29, 2007, 10:56:21 pm »
Thanks everbody I will give the soldering a try. Cheers Graham  :)
« Reply #7 on: July 29, 2007, 11:48:28 pm »
Also, try using "active plumber flux", available from DIY shops.
Peter Fitness
« Reply #8 on: July 30, 2007, 12:42:02 am »
A high wattage soldering iron is the best bet in an existing model, which I did to my first model, after realising the difficulty of getting grease or oil in to an already installed shaft. Having learned from that experience, I now build grease tubes in to all my prop shafts before installation. I usually make my own prop shafts, so adding a grease tube is no big drama, just an appropriately sized hole in the shaft tube, in the correct place of course, silver soldered in. I make a cap tube about 3cm long, of a size that is a neat slide fit over the grease tube, and seal it with a piece of brass sheet at one end. After filling the prop tube with grease, I use waterproof outboard motor grease, the prop shaft is inserted and connected up. When it is necessary to top up the grease, some is inserted in to the cap tube using a small hypodermic syringe obtained from our local vet, without a needle, then the cap is slid over the grease tube, forcing the grease in to the prop tube. I have been asked if grease, rather than oil, places an additional load on the motor. It may do, but as none of my boats are high speed jobs, and all are driven through a belt and pulley reduction, no adverse effects have been noted, and grease is easier to prevent from leakage than oil.
Peter.
BlazingPenguin
« Reply #9 on: July 30, 2007, 08:43:03 pm »
I've always found that when retro-fitting an oiler tube to a shaft, the placing of a section of wet 'spontex' saves premature bonfire celebrations, a tight fitting tube in the hole and pencil gas torch finishes the job. i use a plumbers flux that urns the job pink when the correct heat is reached too.
« Reply #10 on: July 30, 2007, 08:54:04 pm »
Hi all, If you are stuck and you havent got a big enough soldering iron/old fashioned coppersmiths/tinsmiths iron, the type they used to heat up on a gas ring.
Here is an alternative method:
Drill hole in the top of the prop shaft (as mentioned in earlier postings) then you will require a piece of copper tube/brass tube, which is a neat fit over the outside diameter of your prop shaft.  Cut a section off approx 1 inch long - drill a hole in the top of that and solder your Oiler into that.   Make sure that the inside is cleaned up and flush.
Then cut it down the length so that you have 2 x U shapes.   One section with the oiler tube soldered in and the other bit is gash.  Now, rough up the prop tube around the area of where the hole is drilled in the prop shaft and Araldite this U shaped piece in place on top of your prop shaft.
Then, bind over the top with thin copper wire.   Add a little bit more Araldite/Epoxy whatever.
Once it has hardened, run a drill through your oiler tube to ensure that you clear out all Araldite/Epoxy that has formed in the oil tube .
Aye
John E
Bluebird
red
« Reply #11 on: July 31, 2007, 09:12:00 am »
These make it easy if you cannot solder.
http://www.pandanmodelboats.co.uk/acatalog/copy_of_Propshafts.html
Fredy
Captain Povey
« Reply #12 on: July 31, 2007, 12:10:50 pm »
Thanks again all. I checked out the soldering iron and it is only 25 watt and I'm afraid the old copper heat over a gas ring irons went in bin ages ago. As am still not sure there is space to wield a mini gas torch so John's strap on device looks good and I used to be dab hand with the old exhaust bandage and wire applied upside down under a Morris Minor. Failing that I can try the Gruappner ones from Pandan if the mm sizes fit. Cheers Graham. :)
Doc
« Reply #13 on: July 31, 2007, 02:01:16 pm »
I saved all that trouble with oiler tubes and oil by using grease.  I guess it just depends on how you'd rather do it...
 - 'Doc
Bunkerbarge
« Reply #14 on: August 01, 2007, 08:30:12 am »
 - 'Doc
It can also be dictated by the model.  I tried grease in my Revel U-boat conversion but using long thin shafts and very small motors meant the shafts wouldn't even turn.  I was left with needing to use oil and therefore I had to fit a tube in a plastic model.
I drilled the stern tubes to clear the oiler tubes, cleaned out the tubes and holes and araldited the oiler tubes in.  To give the required strength I supported the tubes at the top end with a drip tray and then covered the entire joint area in the hull with a depth of resin.
Sometimes the glued path may be the only one but with a few precautions it can be just as good a job as soldered and a lot less hazardous.
red181
« Reply #15 on: August 02, 2007, 10:53:34 pm »
stupid question, but here goes, I have been forcing grease into my prop shaft with a syringe. I see the value in using oil, less drag etc, but why won't the oil leak out at the propshaft end?, and spray out at the motor end? Thanks
Bunkerbarge
« Reply #16 on: August 03, 2007, 08:57:06 am »
It will, if the clearances are not good enough!
red
« Reply #17 on: August 03, 2007, 09:03:13 am »
 I did post this in "Prop tube oilers "  but it should have been this one
There is another way , leave it dry. at the prop end use a piece of Teflon water acts as a lubricant, and at the top make a simple adapter and use a sealed stainless steel bearing. these are readily available very cheap as the Buggy boys use them just change it once a year or more often if it gets a lot of use.  I used this on a tug that was a problem a few years ago no problems . the adapter needs to be a reasonable fit and can be as long as you want,I just used one grub screw and a bit of lock tight the shaft did have a bit of fall on it so the water runs away when not in use. I also have put a small felt block in or a bit of graffiti yarn as used in steam engines very lose fit this helps.
Fred
A Model World
  • Model Boat Mayhem does what it says on the tin
    • A Model World
« Reply #18 on: August 19, 2007, 09:01:41 am »
two points guys   one for soldering, the electric irons are getting redundant nowadays google the gas cat irons, incredible temperatures and fare neneater and no cord. Secondly graupner do oilers for between 2.40 and 2.80 for 2 dependant on shaft size that just screw in place, for those that hate soldering
Daily flogging?of the ships crew will continue until morale improves
HS93 (RIP)
  • I cannot spell , tough
« Reply #19 on: August 19, 2007, 09:10:46 am »
Model World   look at post 11
« Reply #20 on: August 19, 2007, 03:06:36 pm »
A Model world sorry to correct you but Sealy tools sell irons from 25w to 100w and are readily available from mots good car accessory shop's or motor factors and the 100w wont even break the bank at £25squid
« Reply #21 on: August 21, 2007, 12:25:02 pm »
A point to watch with gas cat irons is the exhaust.  There is a blast of incredibly hot spent gas shooting out sideways.  Not normally a problem out on the bench, but could be a bit thrilling in a confined space, or anywhere near plastic.
« Reply #22 on: August 21, 2007, 12:46:50 pm »
Check out  http://www.expotools.com/   if you think soldering irons are becoming redundant, they have loads from 15w to 175w all makes and sizes. ;)
A Model World
    • A Model World
« Reply #23 on: August 21, 2007, 03:04:55 pm »
Sorry guys I did not make myself clear, Yes there are hundreds of makes of soldering irons out there of the electric variety and still being bought by hundreds of people who have perfect service out of them and do a perfect job, what I should have said is that it seems around me the professional modellers that do this for a living they all use gas cats mostly bought from Maplins when on offer at 20 a set, same can be said of many a modeller we know it seems most are now using gas cats and it just appeared to me that its the in thing but I stand corrected,
The ones that use them and they convinced me they are better use them as there is no cord (which is usually too short) and the temperature's they reach are far far in excess of electric irons. a prime example being soldering suppressors to cans of motors with electric as soon as it touches the can it will automatically cool the iron as the can is cooler so you then wait while it heats up again whereas the gas cat temperature being far higher is pretty what instantaneous. on the down side they do have an exhaust as pointed out and you can melt many a thing with if not watched. As I said I am not advocating its the end of soldering iron electric variety,  its just everyone surrounding us seems to be using them as a back up iron now
HS93 (RIP)
« Reply #24 on: August 21, 2007, 03:29:27 pm »
I solder brass, motors, electronicks ,etc and my irons stay at the temperature they where set at. and as hot as I want them if you pay for Professional equipment , you get temperature and controle
Peter
Page created in 0.034 seconds with 22 queries.
