Hi David
Is the MTB you are building this one http://www.modelboatmayhem.co.uk/forum/index.php/topic,31199.0.html ?
if so the motor in the build model is a Graupner 500 speed running on 8.4 400mAh battery pack
aye
john
Hi John
Yep - that's the one...
I've got the original plans, plus your excellent build log, and a set of scale GA drawings for MTB347 - I've redrawn the plans slightly to lengthen the hull by 20mm (to make it truly 1:32), moved the wheel house back slightly (extending the fore-deck), reduced the rake of the bow to match the GA drawings and am going to try adding more detail.
My aim is to end up with a hull that is proportionally accurate(ish) albeit carries flat-profiles, and a profile and look that is reasonably accurate and detailed...
That's the plan anyway - I'm sure lots of mistakes, frustrations, swearing lie ahead, but then isn't that half the fun?
I started searching for the Graupner 500 Speed motor (rather than deliberately going off-piste), but couldn't find it listed anywhere...hence why I started trying to work it out for myself...?
Battery-wise - Your suggestion is similar to above I guess? A NiMH pack (8.4v rather than 7.2v) with decent capacity for a good bit of running time??
Thanks all - I really do appreciate your help!
