Hello,
I am Kees and I live in Holland. A few weeks ago I bought a Billing Boats kit of the Smit Nederland with the plastic hull. Someone started to build on it years ago but not much work was done (luckily). Only the deck, the railling, shafts and motors were in place.
I paid 50 euro's (+/- 36 pounds) for her, including motors, esc, Futaba 2-channel remote control, battery, charger, fittings, paint so I think thats a good deal.
I never build functional modelships and I have very little experience with it so I didn't want to spend lots of money and with this kit I hope to build a working model for arround 175 euro's (+/- 125 pounds). It is my plan to build here out of the box as much as possible and make a nice working model with the detaills provided in the kit.
This is the model on the shelf at the previous owner. He had it for years and bought it from the guy who started building her
The first thing I did when I got it in my hobbyroom was to rip out all the wooden parts, the shafts, keel, motors..... well I ripped off everything. Sorry but the parts were glued very bad and the glue looked like rotten tar. The hull was not propperly cut out and the shafts and motors were not in line. After this I cleaned her and filled all the holes with styreen and epoxy.
After that I made some openings for the anchors later
And then I installed the beckerrudders again with epoxy.
Here the tunnels and the shafts were alligned and glued in place.
I found on the web that the total weight will be arround 10 kilo's and after I weighted all the materials I figured out that she whould need a few kilo's in ballast. So I added some ballast in the keel to give her a low center of gravity. More ballast will be addes later.
After that I made the steering engine. It was hard to make it without backlash but after some experimenting it worked good.
Then the motors. In the kit were two brand new motors from Graupner but when I checked them on the internet I was not satisfied with the specs. In a dusty corner in my hobbyroom I found a nice Decaperm 6v motor and I decided to us it and on Marktplaats (some kind of E-bay) I found another one. I also made some ferm but flexible couplings (because I didn't like the plastic ones in the kit) and I installed the motors in the hull.
I also did some improvement on the beckers to avoid them cooming apart. (the little brass tube)
I forgot to make greasepipes on the shafts earlier but luckily I managed to solder the on later without doing damage to the hull.
And I installed some grease,dirt and safety guards over the couplings and shafts.
