Author Topic: 3D printed Plug  (Read 5111 times)
3D printed Plug
« on: November 20, 2015, 01:49:58 pm »
Would it be safe to use a 3d printed Plug (skimmed with filler and then painted) for making a fibreglass mould?
Re: 3D printed Plug
« Reply #1 on: November 20, 2015, 01:53:53 pm »
any item can be converted into a plug - if it releases cleanly and care taken.
Re: 3D printed Plug
« Reply #2 on: November 20, 2015, 01:57:59 pm »
I was thinking more about the heat generated and if that would cause problems.  The 3d printing filaments are fairly low melt
Subculture
    • Dive-in to Model submarines
Re: 3D printed Plug
« Reply #3 on: November 20, 2015, 04:16:04 pm »
Won't be a problem.
Re: 3D printed Plug
« Reply #4 on: November 20, 2015, 10:53:37 pm »
Cheers guys.
Planning on making a 1:12 Biber Sub :)
Should come in at a little under 1m long
Ill use the plans to make up a 3D model then cut it into segments for printing.  Join them together, fill and tidy up then create a mould :)
Subculture
Re: 3D printed Plug
« Reply #5 on: November 21, 2015, 06:51:56 am »
I see. From what I've seen of using lower cost 3D printers for larger hull creation, the result does tend to come out rather rough and ready looking. I think traditional crafting techniques take some beating, but you could use your printer to create various parts like the window frames, bulkhead segments, prop and control surfaces.
Page created in 0.014 seconds with 20 queries.
