Author Topic: Model Slipway Yorkshireman v Billing Smit Nederland tug  (Read 6973 times)
shad3925
« on: November 21, 2015, 01:54:18 pm »
I had my heart set on a Model Slipway Yorkshireman and was about to order, I have been offered the Billing Smit Nederland kit at a very very good price.
I would be grateful for any comments and comparisons between the two before finally making up my mind
Reg
Re: Model Slipway Yorkshireman v Billing Smit Nederland tug
« Reply #1 on: November 21, 2015, 02:10:45 pm »
I've not had any experience with the Yorkshireman - the Billings Smit Nederland is very definitely an experienced builders kit, so I guess it's down to whether you feel comfortable with it.
There are a couple of threads currently running on here with regards to the Smit Nederland, including my own, so I'm somewhat biased. %)
shad3925
« Reply #3 on: November 21, 2015, 02:19:46 pm »
Thanks Ray.
Can you enlarge on experience needed for the Nederland.
Reg
« Reply #4 on: November 21, 2015, 02:38:33 pm »
Reg, the term "experienced" is used by the model kit suppliers to indicate the degree of difficulty involved to complete their models to a reasonable standard.
There were no build instructions with mine (good plans though) and I made a lot of mistakes on the way, finally completing the model after 5 years!
Of course, I had very little time available to me then, working away from home a lot.
As you will see on my thread, I'm rebuilding that same model and hoping to achieve a better standard this time around. :-)
GAZOU
« Reply #5 on: November 21, 2015, 03:09:37 pm »
The kit of Yorkshireman is accompanied with a very good note, an impossible to make a mistake, and the manufacturer of the kit is very available.
I would be you I would choose Yorkshireman
radiojoe
« Reply #6 on: November 21, 2015, 04:03:10 pm »
When in doubt get BOTH
shad3925
« Reply #7 on: November 21, 2015, 04:24:17 pm »
Many thanks.
Apparently the newer versions come with a detailed instruction booklet showing every step of the construction.
« Reply #8 on: November 21, 2015, 04:35:24 pm »
Many thanks.
Maybe the manufactures are receiving / reacting to some feedback then...
Whatever you decide - Enjoy!
jarvo
  • Etherow model boat club
« Reply #9 on: November 22, 2015, 12:00:37 pm »
HI Shad
I have built both kits, they do need a bit of nows to build but common sence and a look twice if it dont fit helps, anouther thing, Neddy is a slim hull and yorkie is a tubby hull, motors batteries etc size and weight, all need consideration.
If the Neddy is a lot cheaper then go fot that, Plastic hull or Glass hull, how clumsy are you, strong youkie??????
Hope this helps
Mark
Tugs are for pulling
jarvo
« Reply #10 on: November 22, 2015, 12:05:22 pm »
Sorry Shad
Got carried away, (some think it shoud be permanent!!!!) mixed the neddy and the Rotterdam in hull description. Have built the Rotter as well, Needy is a slightly smaller tug if a car boot size limit is needed, also the neddy should come out slightly lighter, espesialy if you go for batteries instead of lead balast, (take out the batteries)
Mark
Fastfaz
« Reply #11 on: November 22, 2015, 12:33:54 pm »
     From experience with a Yorkshireman they are top heavy and difficult to get the ballast right even then dodgy in windy conditions. I would go for the Smit. Hope this helps.
       Cheers,
           Faz. :-)) :-)) :-)) :-)) :-)) :-)) :-))
shad3925
« Reply #12 on: November 22, 2015, 01:28:22 pm »
Many thanks for all your replies it's been very helpful
Reg
« Reply #13 on: November 22, 2015, 02:28:33 pm »
Hello Reg - PM sent. :-))
Page created in 0.01 seconds with 15 queries.
